High Idle at start-up - JeepForum.com
post #1 of 8 Old 07-20-2009, 10:34 PM Thread Starter
sinbad85
Does anyone have a fix for a 4.7 that will start at 2000 rpm then settle down and idle fine? I cleaned all the sensors (they are only 8 months old). I'm wondering if one went out again or maybe a o2 sensor,fuel reg/filter
Anyone got a fix for it.
Thanks
sinbad85 is offline
post #2 of 8 Old 07-20-2009, 11:19 PM
CULate
1930 J-Series Truck
My 5.9 ZJ starts at about 1500 RPMs then comes down & all the mechanics I talk to tell me that it is normal. It has been checked for sensors IAC cleaned etc. I don't know about the 4.7.
CULate is offline
post #3 of 8 Old 07-20-2009, 11:26 PM
AL04WJ
My 4.0 had an issue where occaisonally it started at 2000 rpms, but not all the time. When it did this the check engine light came on sometimes. It turned out to be the throttle position sensor.
Julian
2004 Laredo 4" lift, 265/75/16 Duratracs, JCR Stage II sliders, ARB bumper and XD9000
AL04WJ is offline
post #4 of 8 Old 07-21-2009, 07:42 AM
Double E
Double E's Avatar
Normal operation for mine.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #5 of 8 Old 07-21-2009, 09:17 AM
01Limited45324
I have an 01 WJ with the 4.7 and it does the same. I posted on here but never got answers, so it's fairly normal. I notice mine does it after three conditions:
1) It's cold out
2) The key was put into the "on" position a few times without starting (i.e. getting codes, etc.)
3) After short trips (less than 7 miles)
-Tom
2001 Grand Cherokee Limited
2002 BMW 530i
01Limited45324 is offline
post #6 of 8 Old 07-21-2009, 09:48 AM
WJChris
WJChris's Avatar
search the TSB's at wjjeeps.com.
there is a TSB for this that requires a computer flash, expect an hour of labor at the dealership
WJChris is offline
post #7 of 8 Old 07-21-2009, 09:57 AM
WJChris
WJChris's Avatar
correction: .5 hrs
here is the TSB:
http://www.wjjeeps.com/tsb/tsb_wj_1801202.pdf
WJChris is offline
post #8 of 8 Old 07-21-2009, 02:08 PM Thread Starter
sinbad85
Looks like we all have a problem, I hate to say something is normal just because some people have the problem, I replaced both sensors on the TB when it started idling high at start up and the problem went away. That was only about 7 months ago so why did it come back? bad sensors again?
Any way thanks for the input guys,
sinbad85 is offline
high idle at start DrEvil ZJ Grand Cherokee Forum 17 11-21-2013 02:02 PM
High Idle at Start up 04StockGC ZJ Grand Cherokee Forum 4 01-05-2010 07:56 PM
High Idle when i first start the ZJ CLNinja ZJ Grand Cherokee Forum 12 07-02-2009 02:21 PM
High Idle at Start- Whats that mean again? JayIV ZJ Grand Cherokee Forum 7 09-11-2007 08:25 PM
'04 Very High Idle at Start - ??? bz_711 ZJ Grand Cherokee Forum 6 07-16-2007 10:51 AM
