I have a 93 ZJ, 4.0L. When I start my ZJ the RPM's shoot up to 2000 and it will slowly increase to 2200. While idling it will drop down in RPM's about every 30sec but it will drop only by a small increment and then it will continue to climb.
I recently changed all plugs, wires, distributor cap, rotor.
I have check for a vacuum leak (didn't find any). I have completely cleaned the throttle body, new gasket and gasket sealer for throttle body, change to a new IAC, Change to a new TPS (second time), checked all plugs.
On the back of the manifold (closest to the firewall) I found a vacuum hose that goes to the passenger fender then it went under the battery tray and stopped. When the engine is on this hose is drawing air. I plugged it and it had no change in my issue. Is this hose suppose to be connected to anything? I looked and didn't find any loose connections (hose). M<y vacuum diagram shows this hose going to "climate control, speed control, 4x4 axle".
Any ideas would be helpful
