High beams stuck on - JeepForum.com
post #1 of 13 Old 05-07-2009, 08:46 PM Thread Starter
Izzy
High beams stuck on
97 ZJ limited
My high beams are stuck on.
The only way I can get them to turn off is by pulling the battery cable.
When I turn the selecter knob, I can see the low beams coming on at the same time as the high beams.
The indicator on the dash won't turn off either.
Any suggestions?
Cheers,
Izzy
Izzy is offline
post #2 of 13 Old 05-07-2009, 08:54 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
There is no relay, it has to be the headlight switch itself where the high-beam contacts have gone bad and "welded" themselves together. I would just replace the headlight switch.
Jerry Bransford is online now
post #3 of 13 Old 05-07-2009, 08:57 PM Thread Starter
Izzy
Thanks for the info.
Is that something I can buy generically, or do I have to go to the stealership?
Izzy is offline
post #4 of 13 Old 05-27-2009, 07:14 PM
nazerine
Figured I may as well post here as I'm having the same issue, but want to confirm a few things...
My highbeams are stuck on too, dash gauge shows headlights off, but highbeams on. All interior lights are lit up too. What's with that if its the high-beam switch???
I pulled the column cover off, and yanked the switch. No continuity between pin 4 and 5, and 4 and 6.. must be faulty switch.
Is it normal behavior when I put the ground back on the battery, for my horn to start blarring? Is there a security mech for when the column is apart?
Thanks in advance guys, hope this is just as simple as replacing the switch... just want to be sure the rest is normal behavior caused by the switch failure.
'96 ZJ Limited 5.2L
nazerine is offline
post #5 of 13 Old 05-27-2009, 07:49 PM
baxy
daytime running light module used to do that all the time on the ram trucks
baxy is offline
post #6 of 13 Old 05-27-2009, 09:40 PM
nazerine
You my friend are correct! I unplugged the module and it fixed the issue, except it seems the module controls turn signals too Key in passenger door fixed alarm issue
DRL Location:
Thanks for the tip baxy, I'm in the Interior too
'96 ZJ Limited 5.2L
nazerine is offline
post #7 of 13 Old 05-27-2009, 09:52 PM
baxy
HMM only thing you should lose when you disconnect DRL is the high beam indicator (which actually cancels the fog light in high beam, which means with DRL unplugged you can have high beam and fog lights on at the same time)
baxy is offline
post #8 of 13 Old 05-31-2009, 03:51 PM Thread Starter
Izzy
If I replace the switch, is it the one on the steering column or the one on the dash?
Cheers,
Izzy
Izzy is offline
post #9 of 13 Old 06-01-2009, 08:11 PM
bad_jeep
Hello,
I am having the same problem with my Cherokee as well.
I had to unplug the cord to the module to shut them off.
I took the Jeep to a mechanic and he said a new daytime running lamp module was needed and would be 300 bucks. I thought that was ridiculous. So after paying him for his short amount of time
I found one at a junk yard for 40 bucks...installed it exactly as the directions above...
and they are still staying on all the time!!!
Any suggestions???
Feeling ripped off by the mechanic!
bad_jeep is offline
post #10 of 13 Old 06-01-2009, 09:16 PM
baxy
maybe the used module is fubar
baxy is offline
post #11 of 13 Old 06-01-2009, 09:35 PM
elmer_fud
the horn blaring is the security system complaining because you disconnected the battery. This is normal, just cycle the key in one of the door lock to disable it.
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #12 of 13 Old 06-02-2009, 11:55 AM
bad_jeep
How do you pull off the column cover to check the switch???
bad_jeep is offline
post #13 of 13 Old 06-02-2009, 07:02 PM
elmer_fud
on my jeep there are 3 screws holding it together/on. There is a flat head one in the center and 2 torx ones, one on each side. You access all three screws from the bottom of the cover.
once the cover is off, the turn signal/high beam/ washer switch is held on my 2 security torx bits if I remember right. The wiring harness has a screw in the middle attaching it to the switches.
I don't know the Torx size, but you will have to use a torx screwdriver. A bit in a handle will not reach up far enough.
Brian
How to run Low and High beams? Sierra2700 ZJ Grand Cherokee Forum 10 02-19-2012 03:51 PM
low beams not working but high beams do? Tapoutzj ZJ Grand Cherokee Forum 6 06-30-2009 11:46 AM
Low beams on with the High beams? MeWJWifeZJ ZJ Grand Cherokee Forum 11 01-29-2009 04:57 PM
high and low beams? H0miegwillikers ZJ Grand Cherokee Forum 6 02-09-2007 01:31 PM
high beams on with low beams WJ devile ZJ Grand Cherokee Forum 14 11-27-2006 01:17 PM
