hid install not working need help - JeepForum.com
post #1 of 16 Old 01-09-2012, 06:38 PM Thread Starter
uniquevibez
1994 ZJ
Ok jus bought a HID conversion kit an installed in like 10 minutes pretty easy. However once I was done I started up the jeep an the lights blinked once an then shut off.
Anyone run into this an have a solution?
uniquevibez is offline
post #2 of 16 Old 01-09-2012, 06:48 PM
zander21510
Did you check the fuse? You might have blown it, sounds like it overloaded the circuit.
zander21510 is offline
post #3 of 16 Old 01-09-2012, 10:26 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
My personal suggestion is to return it for a refund and then do a 9007 halogen bulb conversion.
ratmonkey is offline
post #4 of 16 Old 01-10-2012, 11:12 PM Thread Starter
uniquevibez
1994 ZJ
Fuse is fine and I was told to run a relay set up but not sure how to go about that
post #5 of 16 Old 01-11-2012, 07:43 AM
somebody5788
1994 ZJ
I agree with Rat lol.
The ballasts you bought have the classic cheap ballast issue. You should never really "need" a relay kit on a 55w Halogen wiring harness. You should also never use halogen reflector housings with HID bulbs.
2006 Honda 919
1994 Jeep ZJ
2007 Nissan Titan
1997 BMW 328is
somebody5788 is offline
post #6 of 16 Old 01-11-2012, 08:57 AM
funfactor89
the hid's are telling you something get rid of them
funfactor89 is offline
post #7 of 16 Old 01-11-2012, 09:25 AM
PAFirefighter11
Quadratec Live Chat Rep
PAFirefighter11's Avatar
2015 JK Wrangler
Do you have a wiring harness upgrade or are you trying to run these on the stock wiring?
Also, do you enjoy blinding people? If you're running these in the stock housings .. STOP! Do a full HID retro like I and others have done, or go back to halogens.
-Rick R
-2015 JKU - 3.5" JKS JSPEC Kontrol, 315/70R17" MTZ's, 17x9" Quadratec Rubicon Xtreme's, JCR bumpers & skids, JW Speaker tails, Dirty Dog netting/screens, Quadratec Auto Mirror Movers, etc
-03 VW Golf TDI - Diesel
-FDNY 9/11/01 - All gave some. Some gave all.
PAFirefighter11 is offline
post #8 of 16 Old 01-11-2012, 02:53 PM Thread Starter
uniquevibez
1994 ZJ
First off love how people assume I'm being an ******* sry for bein a noob to hids I did buy new lenses anyways I'd rather just use the ones I have since I already have them so if anyone has an positive advice let me know thanks. And yes these are plug an play kit goin off factory harness
post #9 of 16 Old 01-11-2012, 03:10 PM
somebody5788
1994 ZJ
That still sounds like a halogen housing to me? The problem is you're not giving us ANY information here. Like what you have, where you bought it, or anything that is pertinent. Basically that just leaves us to assume you're running an ebay kit and possibly clear lens headlights (which still glare just as bad)
2006 Honda 919
1994 Jeep ZJ
2007 Nissan Titan
1997 BMW 328is
post #10 of 16 Old 01-11-2012, 05:10 PM
General_Jeep
1994 ZJ
Personally I did the 9007 swap and it was a hell of a better then the ultra sylvania 9004(atleast 50% more light). it was just a cheap pair of 9007. Currently running the 9007's as Ultras but will upgrade to HID's with a projector retrofit.
1994 Jeep Grand Cherokee 5.2L V8- NV3500 - Blown D35 8.8 replacement some day.
2010 Jeep Patriot 5 speed manual-- DD, 27-31MPG :D
1996 Dodge Ram 1500 - Work Truck/Plow 5.2L NV3500
2005 Nissan Titan - Hauler
"The Jeep is Americas only real sports car!" - Enzo Ferrari
General_Jeep is offline
post #11 of 16 Old 01-11-2012, 07:07 PM
PAFirefighter11
2015 JK Wrangler
That's your problem - factory wiring. Buy one of these:
http://www.theretrofitsource.com/index.php?cPath=28
And a pair of these:
http://www.theretrofitsource.com/pro...oducts_id=3181
What brand HID kit, what color temp? The negative comments in this thread are normal. HID's in reflector housings are not the right way to do things. It's illegal, dangerous, and incredibly obnoxious to all oncoming traffic. It definitely gets my high beams when I see oncoming PnP's in factory housings blinding me... and you don't want to be on the receiving end of my high beams. At the very least a set of E-codes would do you well, but since that's almost impossible to find on ZJ's you need projectors that I linked above. Please do it the right way...
Would you rather this:
Or this (This is my setup still needing slight rotational adjustment):
-Rick R
post #12 of 16 Old 01-12-2012, 07:51 AM Thread Starter
uniquevibez
1994 ZJ
It's a mcgloughlin 6000k plug an play kit and thank-you PAFirefighter11 for your positive advice an I will be getting those... the ones I bought were 30% off reason y I bought them
post #13 of 16 Old 01-12-2012, 08:00 AM
bobk83
Sometimes the polarity is reversed on the kit, try either flipping the harness around on the plug going to the jeeps harness or at the ballast itself. if the 12+ and ground are reversed it will turn on and kick off.
bobk83 is offline
post #14 of 16 Old 01-12-2012, 08:01 AM
somebody5788
1994 ZJ
I've never run a relay kit on my Phillips ballasts. Good ballasts don't need upgraded wiring because they use less current. A 55w halogen bulb uses more current then most HID kits.
BTW it looks like yours shipped with the same problem mine did. 1 Lens has washers and the other doesn't. If you put some small washers on your passenger side between the projector lens and the reflector, that will give you the same crisp blue cut off as your drivers side.
2006 Honda 919
1994 Jeep ZJ
2007 Nissan Titan
1997 BMW 328is
post #15 of 16 Old 01-12-2012, 08:09 AM
PAFirefighter11
2015 JK Wrangler
You're welcome. Never heard of that brand so I can't comment on the quality, etc. Look at a relay as that may be the issue.
I run relays for the high beam control. I'm a huge fun of having bi-xenon HID's and most setups require the relay harness due to the cutoff shield solenoid control.
The passenger side cutoff was perfect when I first ran it (24 hours or so). It then faded to what you see. The reason for this is the cutoff shield is not popping completely back into the proper location. This seems to be an MH1 issue and doesn't really bother me that much. This kit is sold, though, to my buddy. The new MH1's I have supposedly still have hit or miss issues with the sticky cutoff shield. We'll see how it goes
-Rick R
hid , install
Windows not working! working on it now need quick response please Ganjatrooper ZJ Grand Cherokee Forum 20 10-15-2011 02:27 AM
Sony install Rear speakers and AUX not working mikezjeep ZJ Grand Cherokee Forum 1 09-09-2011 11:27 AM
Cruise not working/AC not working correctly: Need Vacuum line diagram JoshuaDHarp ZJ Grand Cherokee Forum 3 07-28-2011 05:20 PM
ZJ radiator install, best spark plugs, bumper guard install doccjp ZJ Grand Cherokee Forum 10 09-30-2010 07:20 PM
IRO 4'' LA install complete!!!! post install questions (pics to come) FrankTheDank ZJ Grand Cherokee Forum 9 07-12-2009 08:51 PM
