Hi/Lo shifting - JeepForum.com
post #1 of 6 Old 11-20-2002, 12:37 PM Thread Starter
Beachead19
Beachead19's Avatar
Hi/Lo shifting
Is it normal for the Jeep (98 ZJ 4.0 AWD) to grind momentarily as I shift from Neutral to 4wheel Hi or Lo? I have the transmission in neutral also. (Following owner's manual still gets a grind feel/noise)
98 ZJ Limited I6
OME SD40
BFG AT
Kolak Ignition
Beachead19 is offline
post #2 of 6 Old 11-20-2002, 07:07 PM
Camster
Camster's Avatar
i'm guessing you mean the quadra-trac full time 4wd system. that is different from an AWD system. no jeep comes with AWD. what you have to do is get up a little momentum (5 mph) they put it into neutral and yank up on the shifter lever. put it back in drive BEFORE you stop rolling and it should shift in properly. just ask if you need any more help.
Cameron
Camster is offline
post #3 of 6 Old 11-20-2002, 08:50 PM Thread Starter
Beachead19
Beachead19's Avatar
Its the transfer case that grinds when I move from neutral to 4Hi or 4Lo. The transmission has no grinding at all. I am moving about 5mph while shifting and have checked each Diff. fluid level.
98 ZJ Limited I6
OME SD40
BFG AT
Kolak Ignition
post #4 of 6 Old 11-20-2002, 11:41 PM
BEATERCJ
1981 CJ5
like the fellow said get up to 5 mph and shift the tranny into neutral , then in one motion pull the t case into what ever gear you want, DO NOT pause in neutral.......
i work to buy more jeeps and work on them... have four need more..
2002 grand, 1995 yj, 81cj5, 53m38,looking for a willys truck, 2003 rubicon edition on the way yee haa 03 rubi died a moose wanted a closer look... bought a 08jk two door. Ox front locker soon to be detriot rear...
BEATERCJ is offline
post #5 of 6 Old 11-21-2002, 05:14 AM
Camster
Camster's Avatar
well you're doing what you're supposed to. if you're still under warrantee i'd take it to the dealer to have it checked out.
Cameron
Camster is offline
post #6 of 6 Old 11-25-2002, 01:46 AM
Ryan2son
Quadra Trac II addition...
On mine I put it in park then shift. No problems here...
Richard
Richard
1999 Jeep Grand Cherokee Laredo
4x4, 4.7 V8, Quadratrac II, Loaded
A Hail the Mighty Philadelphia Eagles!
Ryan2son is offline
Shifting tommylee84 ZJ Grand Cherokee Forum 6 04-14-2009 08:40 AM
Shifting into 4wd BirdDaKiLLa ZJ Grand Cherokee Forum 1 12-25-2008 01:46 PM
not shifting out of second 04gclimited ZJ Grand Cherokee Forum 5 06-18-2007 07:21 AM
Not shifting normally from 1st to 2nd subkron ZJ Grand Cherokee Forum 2 06-22-2005 05:43 PM
94 ZJ 5.2L not shifting LonAllen ZJ Grand Cherokee Forum 6 01-31-2005 06:53 AM
