HHR Fan swap - JeepForum.com
post #1 of 22 Old 09-23-2013, 02:24 AM Thread Starter
Josef86
I had a 2 speed taurus electric fan and killed it last summer while testing the Snorkel. So I've been running the taurus shroud with a generic autozone 16" efan . It's not cutting it. I'm over on the mopar forums and ran across the HHR fan being a popular mod. I just went out and measured my all-aluminum 3 core radiator on my 5.2L. The HHR fan measures 22" wide, 18" tall, and 4" deep. My radiator's fine surface area(same size as the stockers) is 22-1/4 wide, 19" tall, and there is about 5 -1/4" of clearance between the radiator and water pump pulley. Pros over taurus fan *$60 for fan and shroud assembly *Much less draw(15amp) and doesnt spike badly like Taurus fans do *Dimensions fit like a glove *Flows atleast 3000cfm I know a few guys that have to run dual fans because they dont have proper shrouds. But this should fit perfectly. I'll post up pics after it is delivered this wen and installed. I wanted to share this for those who want to get a cheap electric fan and want something that will be efficient.
UPDATE: Fan is installed. Working great. I have now had it running with the AC on constantly, in Houston heat and driving. Stays right below 210* with AC on in Houston traffic. Check post on page 2 for any other info.
Josef86 is offline
post #2 of 22 Old 09-23-2013, 04:57 AM
moggie99
Sorry - I'm not familiar with "HHR" fans. Could you give more detail?
Richard Moss
'96 ZJ 4L auto, '95 XJ 4L manual, 2000 Nissan Patrol Y61
In the UK: 1969 MGC GT
moggie99 is offline
post #3 of 22 Old 09-23-2013, 06:48 AM
x10radsponge
I think he is talking about the Chevy HHR, their answer to the PT Cruiser.
x10radsponge is offline
post #4 of 22 Old 09-23-2013, 06:59 AM
riot1987
I dont see why it wouldnt fit. Ive heard of people running many different kinds of fans. Good luck man!
Build thread^^
riot1987 is offline
post #5 of 22 Old 09-23-2013, 07:01 AM
970001zj
3000's not gonna cut it bub
970001zj is offline
post #6 of 22 Old 09-23-2013, 07:18 AM
riot1987
Fan expert here^^
Build thread^^
riot1987 is offline
post #7 of 22 Old 09-23-2013, 07:40 AM
970001zj
Originally Posted by riot1987 View Post
Fan expert here^^
do you even e fan ?
970001zj is offline
post #8 of 22 Old 09-23-2013, 07:49 AM
970001zj
could work though
in the winter
lol
post a vid after its done and prove me wrong
if it dont work get an mk8 / t-bird e-fan
970001zj is offline
post #9 of 22 Old 09-23-2013, 08:31 AM
dnuccio
3000cfm not enough? Im wanting to add an e fan to mine, and I was looking at a 3000 cfm unit from Summit Racing.
What is your reccomended cfm?
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #10 of 22 Old 09-23-2013, 08:57 AM
970001zj
over 9000
970001zj is offline
post #11 of 22 Old 09-23-2013, 09:03 AM
970001zj
really though 5000 is the stock mech rating
my mk8 is about 6000 or more on high
really though i only turned it to high a few times but i dont know what kinds of hell you guys put your cooling systems thru
so i say more than stock because i was always overheating with the stock fan and a/c on
970001zj is offline
post #12 of 22 Old 09-23-2013, 09:09 AM
dnuccio
over 9000
-_-
R.I.P. Ratmonkey
dnuccio is offline
post #13 of 22 Old 09-23-2013, 09:10 AM
Jeeples
Jeeples's Avatar
Most everything I've seen online shows them rated at around 4000 CFM, which if I'm not mistaken is what the 3.8 Taurus fans are rated at. The biggest plus is the lower amperage draw, since the HHR fans pull less than 20 amp. They're also pretty cheap, with new ones running right around $100.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #14 of 22 Old 09-23-2013, 09:16 AM
970001zj
mk8 = 4000 on low and 15$
970001zj is offline
post #15 of 22 Old 09-23-2013, 09:18 AM
970001zj
but since there are few left to pick from the hhr could be the next new thing
seems like a good idea if it works
970001zj is offline
