Hey For You Axle And Gear Junkies...HELPPP! - JeepForum.com
post #1 of 20 Old 01-15-2008, 12:47 PM Thread Starter
ZJForBreakfast
What axles came stock on a 93 ZJ? Also i think i screwed up the gears in my front axle, i should hit up the local jeep junkyard right , that is since i want the same gears that were in their previously. Please give me the down low, THANKS
When the asteroid hits, you think 2WD will make it? NAHHH
ZJForBreakfast is offline
post #2 of 20 Old 01-15-2008, 12:48 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
D30 front and D35c rear.
V8's had 3.73 gearing.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #3 of 20 Old 01-15-2008, 02:06 PM
MuddyLuxury
MuddyLuxury's Avatar
I-6 had 3.55
-Jeb
99 WJ 4.7V8 selc-trac swap
285s re-tread
IRO 6.5 Long Arms
Aussie Locked Rear
in the works... lots deployments are great for jeep budgets
Go Doorless!
Things i need..
good spots in the mid atlantic to camp, hike, fish, kyak and wheel, if you know please share
Originally Posted by 5.9 ANDY
i would do the rear.
MuddyLuxury is offline
post #4 of 20 Old 01-15-2008, 02:09 PM
ArloGuthroJeep
Mr. Hyde!
I6 could have 3.73 if it had the tow package
post #5 of 20 Old 01-15-2008, 02:38 PM
MuddyLuxury
yes sir you are correct, so it's ten lashings with an old fan belt? or a good flogging on the bull bar?
-Jeb
285s re-tread
IRO 6.5 Long Arms
Aussie Locked Rear
Go Doorless!
Things i need..
post #6 of 20 Old 01-15-2008, 03:18 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
both, ill get the fan belt....who has a bull bar?
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #7 of 20 Old 01-15-2008, 07:27 PM
PR1AWRet
2002 KJ Liberty
If you are going to hit up the JY, get a high pinion D30 from a Wrangler.
PR1AWRet is offline
post #8 of 20 Old 01-15-2008, 08:56 PM
cherokeeguy89
Mine has 3.73's from the factory and a rear lim slip, but didn't have the towing package. Go figure. I put the hitch on myself.
Keep Jeepin
cherokeeguy89 is offline
post #9 of 20 Old 01-15-2008, 09:06 PM
MuddyLuxury
woh woh woh.. tis not both, its an either or
-Jeb
285s re-tread
IRO 6.5 Long Arms
Aussie Locked Rear
Go Doorless!
Things i need..
post #10 of 20 Old 01-15-2008, 09:19 PM
ArloGuthroJeep
Mr. Hyde!
You must have had the tow prep group then?
post #11 of 20 Old 01-15-2008, 09:56 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
This is like reading a transcription of a bunch of old men sitting around a barber shop.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #12 of 20 Old 01-15-2008, 10:13 PM
MuddyLuxury
Hunter
i'm pretty sure that was a compliment?
-Jeb
285s re-tread
IRO 6.5 Long Arms
Aussie Locked Rear
Go Doorless!
Things i need..
post #13 of 20 Old 01-16-2008, 10:50 PM Thread Starter
ZJForBreakfast
what kind of ring will i need to get if i get that high pinion from the wrangler at the junkyard?
post #14 of 20 Old 01-16-2008, 10:52 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
dont get it with a vacume disconnect, if i were you, i would get a 30HP outof an XJ so it is a direct swap, then get the gears out of a YJ with a 4banger, they are 4.10's....thats what i did on my jeep.
build thread:
5.9 ANDY is offline
post #15 of 20 Old 01-16-2008, 10:54 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
ok, fan belt.
build thread:
5.9 ANDY is offline
wireless ignition node LOCKOUT! HELPPP! yochay101 WK Grand Cherokee & XK Commander Forum 3 11-14-2008 06:00 PM
Hvac Removal Helppp!! 99 Wj GRDCHRKE555 WJ Grand Cherokee Forum 21 08-02-2007 12:28 PM
ZJ front CV driveshaft helppp apex96zj ZJ Grand Cherokee Forum 9 05-18-2007 10:06 PM
$1 if you can name the application for this gear/axle sand zj ZJ Grand Cherokee Forum 45 02-22-2007 10:36 AM
HELPPP !!! windows not going down meowmixxer ZJ Grand Cherokee Forum 4 07-24-2005 01:39 AM
