Hessitation w/ Low Fuel Level - JeepForum.com
post #1 of 3 Old 09-15-2009, 06:34 PM Thread Starter
soundguy787
About 2 months ago my Jeep Started hesitating while having low fuel levels. Its only when you are going around corners, or if its really low going straight and stomp on it, you can put the pedal on the floor and it does nothing then BAM theres the power- its not a transmission problem. I did drop the tank around the same time the problem started to check for a fuel leak witch i was unable to find (It pisses fuel out the top when very full- have read i need to replace my fuel pump gasket) Anyone have any ideas???
soundguy787 is offline
post #2 of 3 Old 09-15-2009, 06:42 PM
WhiteOut
WhiteOut's Avatar
I would think that this is normal. When you go around a corner the gas will slosh to the side and if its low enough there wont be any fuel reaching the pickup. Same with accelerating in a straight line, as you move forward from a stop or lower speed quickly, the fuel is pushed to the rear of the tank.
WhiteOut is offline
post #3 of 3 Old 09-15-2009, 07:19 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Clogged fuel pump filter. or bad fuel pump. That is NOT normal, it doesnt happen from the factory so why would you think that it is normal? If it is leaking, you either need to replace the gasket, or if you have had the fuel pump out recently, the top probably isnt tight enough. (its pretty tough to get it tight with out the tool, but it can be done with a BFS and rubber mallet)
~James
ezflip is online now
Low fuel level warning....coming on very late? kunzet WK Grand Cherokee & XK Commander Forum 6 03-24-2009 03:26 PM
Level Kit NewJeepFever ZJ Grand Cherokee Forum 17 09-25-2008 11:42 AM
ZJ Not Level Steve98 ZJ Grand Cherokee Forum 5 07-27-2007 11:07 PM
zj oil level. Derek33 ZJ Grand Cherokee Forum 10 05-24-2005 08:51 PM
Fuel level gauge Mav ZJ Grand Cherokee Forum 10 05-11-2005 02:36 PM
