??? Hesitation ???? - JeepForum.com
post #1 of 15 Old 05-20-2006, 09:21 AM Thread Starter
matts98ZJ
matts98ZJ's Avatar
??? Hesitation ????
When i pull off sometimes it seems like its going to die it spudders and back fires just a small amount then it goes like nothen is wrong. dont do it all the time...
Any Ideas would be a big help
matts98ZJ is offline
post #2 of 15 Old 05-20-2006, 10:18 AM
Varkyl
No where near stock
Varkyl's Avatar
I am having the same problem. It doesn't do it all the time but usually does it after it has been driven then parked for about 10 to 15 minutes and then driven again. And it only does it on the first acceleration and after it does the little sputter and pop it runs perfect.
One of these days I will look into it a little further and should have more info then.
Nathan
One slightly modified '96 ZJ
new sig coming soon
Varkyl is offline
post #3 of 15 Old 05-20-2006, 11:19 AM
laxwarriors21
laxwarriors21's Avatar
Same thing happens to mine every once in a blue moon! So if yall figure out what it is, then let me know.
--4.5'' RE Lift
--31'' x 10.50'' Firestone Desination MT's
--Trail ready bumpers
--Conferr roof rack
--Two Hella Model 500 driving lights
laxwarriors21 is offline
post #4 of 15 Old 05-20-2006, 11:42 AM
97zjjeeper
97zjjeeper's Avatar
ya my jeep does that to start off then BLAAAAAAAAA nothing pop then off she goes
Tater
BLACK 97 ZJ 4.0L-42re-242-DANA 30/35 (3.73)
MODS) 2in lift-30x9.5x15 BFG A/T-15x8 Pacer Wheels-K&N Intake-1in TB Spacer-40Series Flowmaster-Hi-Flow Cat-JKS Trackbar-Sliderz-BDS adj CA-BDS SS-Cobra19 ULTRA III-FireStick4FT-PA Horn-Hella500 DL-Roof Rack-TC Skid-Gastank Skid
97zjjeeper is offline
post #5 of 15 Old 05-20-2006, 02:15 PM
ajmorell
ajmorell's Avatar
I have the same thing sometimes. Every now and then I will throw a code. I don't know what number it was but I had it ran to see what it said and it came up that my downstream O2 was having some goofy voltage deal, like it would alternate high then low. Basically what the mechanic told me is sometimes what would happen is it would get this bad voltage reading and tell the ECU that the engine was too lean so it would give it more fuel and it would then actually be running rich causing the hesitation. I believe he said this problem was caused by my crappy catalytic converter messing up my downstream O2 sensor or the wiring was corroded on the sensor, I can't remember which.
ajmorell is offline
post #6 of 15 Old 05-20-2006, 02:30 PM
greasefingers
greasefingers's Avatar
1994 ZJ
Thatís exactly how the O2 sensor works Ö it oscillates between 0.1 to 0.9 volts, in a sine-wave manor. Anything below 0.45 is lean (too much oxygen) and anything > 0.45 is rich. The upstream O2 sensor is used by the PCM to fine tune the air-to-fuel ratio. The downstream one only tells you when the Cat is spent.
I would concentrate in other areas for sluggish acceleration.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #7 of 15 Old 05-20-2006, 03:38 PM Thread Starter
matts98ZJ
matts98ZJ's Avatar
I have no idea. cleaned intake system from manifold to injectors. Only does it like someone say about driving then park for 15 min or so like if you going in to a store then leaving when you pull out it does it. the it runs great after that....
post #8 of 15 Old 05-21-2006, 08:20 AM
KingPrat
My mechanic told me that problem was caused by my cracked exhaust manifold. It went away when he welded it, but seems to have reared its ugly head again.
New: Steel Blue 2001 Laredo 4.7, QD, Exhaust
Nokian Vatiiva tires: 235/65-17
Previous:1997 ZJ TSi 4.0. Some stuff added
Western New England College '08
Golden Bear Lacrosse #13
Week 11 USILA Rank: #15
2008: 16-5
NCAA Elite 8
TCCC Champions
KingPrat is offline
post #9 of 15 Old 05-21-2006, 09:28 AM
doyll
Could possibly be caused by a hot engine compartment vaporizing the fuel in the lines & rail when parked. (engine off, no fuel moving in lines & injector rail) After starting it will run okay on vapor/liquid mix until you hit the throttle, then it's squirting too much vapor and not enough liquid through injector (engine stumbles gasping for fuel) until liquid fuel replaces vapor in rail and injectors are quirting liquid. Then engine runs like nothing is wrong again. Until you park it and hot engine compartment does it again.
Easy way to test this would be to open your hood when you park and see what it does when you start and drive off in 10-15 minutes vs. hood closed under same conditions.
1997 ZJ 4.0, 42re, 242, 3.73, tow hooks, reciever hitch, skids, OBA, F>R lift, Rancho 9000s, Addco 1.25", JKS discos, 265/75r MTs on stock wheels, 99+ intake, Banks look-alike header, sliders,
NEED: adjustable upper front control arms, front track bar frame bracket for JKS/RE bar, adjustable rear track bar, Addco rear sway bar, winch
doyll is offline
post #10 of 15 Old 06-13-2006, 10:17 AM
Invisible
That is interesting. I have the same problem, and was constantly throwing a "too lean" code. But the funny thing is, it seems to have gotten worse sense I put a new Cat on mine!
Anyone else have any information?
Invisible is offline
post #11 of 15 Old 06-13-2006, 10:34 AM
ajmorell
ajmorell's Avatar
Did you try replacing the upstream O2? That would be my next area to check out.
ajmorell is offline
post #12 of 15 Old 06-13-2006, 10:43 AM
reneveah
2003 WJ
this may be the cause, read http://www.wjjeeps.com/tsb_list.htm#1803103
03 Jeep WJ Overland>
91 Ford Taurus>
reneveah is offline
post #13 of 15 Old 06-13-2006, 11:26 AM
Invisible
I did replace that. About a year and a half ago I think.
Cat, muffler, starter were in the last 3 weeks.
post #14 of 15 Old 06-18-2006, 02:46 PM
Invisible
I think I may have found the problem. My Dad was searching Technical Service Bulletins on our library's website and found:
TSB number 18-02-98
Subject: Long Crank Times/Sags/Hesitation or Slow run Up
Date: 2/6/1998
It's for 96 ZJ's, but it may help everyone. (with the 4.0 anyway)
Condition: Long Crank times/sags (etc) after a cold drive-away start. This condition is caused by an ignition switch triggered reset of the Power Train Control Module (PCM) which caused adapitive memory loss in the PCM.
Diagnosis: Using the Mopar Diagnostic system (MDS) or the Diagnostic Scan Tool (DRB III) with the approriate manual, verify all engine/transmission systems are functioning as designed. If Diagnostic Trouble Codes are present, record them on the repair order....
Anyway it gives the repair procedure, but I guess you'll have to go to a Jeep dealership to get it done. So good luck to everyone, and I'll be calling the dealership tommorw.
post #15 of 15 Old 06-24-2006, 12:19 PM
Invisible
Had the prodedure done today. So far so good. I will let you know if it comes back.
4.0 hesitation underpowered ZJ Grand Cherokee Forum 9 12-21-2011 11:35 AM
Hesitation again! What gives???? jeepguy98 ZJ Grand Cherokee Forum 1 07-21-2009 10:03 PM
Take-off Hesitation JPM WK Grand Cherokee & XK Commander Forum 15 04-04-2008 05:46 PM
hesitation??? Heffa ZJ Grand Cherokee Forum 3 09-02-2006 03:46 PM
hesitation? brewmaster33 ZJ Grand Cherokee Forum 0 10-16-2003 09:20 AM
