hesitation - JeepForum.com
post #1 of 7 Old 06-10-2013, 10:41 AM Thread Starter
harv51
hesitation
new to the forum and already have question. 98 cherokee has bad hesitation when starting off. im thinking fuel pump any suggestions?
harv51 is offline
post #2 of 7 Old 06-10-2013, 03:07 PM
JasonStebbins
Kind of vague. Is it sputtering/slipping/stalling/backfiring/misfiring? Is the idle smooth?
When is the last time you did an ignition tune-up?
Check fuel pressure at the rail?
Battery terminals clean and tight? All grounds clean and tight?
Ever clean off the IAC?
Poop
JasonStebbins is offline
post #3 of 7 Old 06-10-2013, 05:54 PM Thread Starter
harv51
sorry about being so vague. i just bbought it. havent had time to do much to it . it acts like it is starving for fuel.thnx for the reply.
harv51 is offline
post #4 of 7 Old 06-10-2013, 06:35 PM
dellis
2005 WK
If it is the fuel pump, I would surmise that you would experience problems at times other than just starting out. But, to be sure, can you put a fuel gauge on the rail and give us the readings/behavior when you start up both at idle and as the engine gets revved?
dellis is offline
post #5 of 7 Old 06-10-2013, 10:23 PM
Oldfrog
2007 WK
Yeah, I'd check fuel pressure at the rail, but I bet the old engine is just dirty and/or carboned up.
Pour 1/2 can of Seafoam in your fuel tank for starters. If that doesnt work after about 100 miles, then change the spark plugs, wires, rotor cap, distr. cap and then clean your throttle body. Do NOT let the coil wire cross any of the the plug wires as it exits the distr. cap when you swap wires. Go ahead and swap the air filter element and check for vacuum leaks too.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #6 of 7 Old 06-18-2013, 03:42 PM
pitch123
my ZJ started slow. it needed more cruck than usual. two weeks ago, it can not start after I finished shopping. It turned out a bad starter. It starts quickly with the new starter.
pitch123 is offline
post #7 of 7 Old 06-18-2013, 04:17 PM Thread Starter
harv51
well pulled the tank off replaced fuel pump runs like a top. thnx for suggestions
harv51 is offline
