HELPPP !!! windows not going down - JeepForum.com
post #1 of 5 Old 07-22-2005, 03:11 PM Thread Starter
meowmixxer
so all four of my windows ahvent been going down for the longest time now, and i jstu recently decided to get it fixed after we got a long streak of way hot weather, so heres the deal. all four of the windows are getting power to them, and i hooked a ground up to the switch in the drivers front door to replace the old one, and now my drivers door and the passanger rear door rolls down. but not the other two. so any ideas what it could be ? is there maybe a bad ground under the hood ? or could it be the master switch ? any help will be greatly appreciated.
oh and it has had some times where the underhood has been really muddy/dirty if that helps. and help once again greatly appreciated
1993 Jeep Grand Cherokee 4.0l
2001 Toyota MR2S
1970 Dodge Dart Swinger
J - rides minnesota
meowmixxer is offline
post #2 of 5 Old 07-22-2005, 07:23 PM
jgoode3402
jgoode3402's Avatar
Do they go down when you use each of the door switches independently? If so, I would guess that it is the driver's master switch.
'97 XJ Country
3" Rusty's AAL w/BFG a/t 31x10.50
Stock wheels & BS
XM Radio
jgoode3402 is offline
post #3 of 5 Old 07-22-2005, 08:21 PM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
Check the wires where they run from the door into the body. I had an XJ that broke the ground wire in the boot anad the same thing happened, no window power or door locks.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #4 of 5 Old 07-23-2005, 12:20 AM Thread Starter
meowmixxer
well they dont go down by there own switches independantly, and all the power door locks work fine. but i will check the ground in the boot. because before i rigged up a new ground none of them went down, and now that i have my rigged ground the two windows stated roll down, so i do not know why the other two wont roll down.
2001 Toyota MR2S
J - rides minnesota
post #5 of 5 Old 07-24-2005, 01:39 AM Thread Starter
meowmixxer
i was going to do some mroe checking todya but we just got messed uup by a huge stormthat left us with a massive heaty humid deathtrap so no goin outside or in the jeep today
2001 Toyota MR2S
J - rides minnesota
wireless ignition node LOCKOUT! HELPPP! yochay101 WK Grand Cherokee & XK Commander Forum 3 11-14-2008 06:00 PM
Hey For You Axle And Gear Junkies...HELPPP! ZJForBreakfast ZJ Grand Cherokee Forum 19 01-18-2008 12:02 PM
windows zjberry ZJ Grand Cherokee Forum 4 12-17-2007 06:11 PM
Hvac Removal Helppp!! 99 Wj GRDCHRKE555 WJ Grand Cherokee Forum 21 08-02-2007 12:28 PM
ZJ front CV driveshaft helppp apex96zj ZJ Grand Cherokee Forum 9 05-18-2007 10:06 PM
