Quantcast Help! Working on plenum gasket and broke an intake manifold bolt! - JeepForum.com
Jeep Home Jeep Forum Jeep Classifieds Jeep Registry JeepSpace Jeep Reviews Jeep Gallery Jeep Blogs Jeep Clubs Jeep Groups Jeep Videos Jeep Events Jeep Articles
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Help! Working on plenum gasket and broke an intake manifold bolt!
Free Shipping on all Engo Winches Continues...starting at Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineONBOARD-AIR.COM: Economy OBA System
JeepForum Membership Drive - Reduced Premium Membership For a Short Time Only
Old 07-31-2010, 04:02 PM   #1
comptiger5000
5.9 Addict
I'm in the middle of my plenum gasket job, and all set to start reassembly, when I remembered that the front pass. side bolt on the intake manifold snapped when I went to remove it. So, I've got to get what's left of it out of the head.
It's completely rusted in. I've soaked it in PB blaster 5 or 6 times, tried freezing it, and still can't get enough grab to get it out with Vice Grips. So, I went and bought a screw extractor, except it snapped before it even began to move the bolt (it's really, really stuck). What should I do?
I'd like to have her running again tomorrow, and don't want to have to have her towed to a shop on Monday. Help is greatly appreciated.
comptiger5000 is offline   Reply With Quote
Old 07-31-2010, 04:24 PM   #2
jhotrod83
They make special extractors you can get through a tool dealer like mac tools or snap on tools that works very well. It is a reverse drill bit with a splined rod a little bigger than the drill bit. If the reverse pressure from the drill bit doesn't pull it out then you hammer the splined rod in and twist it out. I'm not sure if you can find those tools locally. Ask a few nicer mechanics to borrow theirs or try to find them in local stores. Otherwise you will probably have to tow it
95 Limited 5.2, 7in lift 8 adj control arms, 36x13.5 iroks, custom 3in y pipe, high flow magnaflow cat flowmaster 40, KOR radiator suport, and plenty of trimming
jhotrod83 is offline   Reply With Quote
Old 07-31-2010, 04:25 PM   #3
comptiger5000
5.9 Addict
I don't think anywhere local has them. The problem is, it's a 1/4" bolt. Anything I put in there isn't very strong. The last attempt I made simply sheared the extractor in half (basically a reverse drill bit).
Old 07-31-2010, 04:29 PM   #4
jhotrod83
These bits come small too and are meant for high pressure. The bolt you are trying to get out should be a 5/16 bolt so you have plenty of meat to drill. It sux but it sounds like you will have to drill. Is there any bolt sticking out? Pics?
Old 07-31-2010, 04:29 PM   #5
bigbossd1030
Try heating it with a torch.
Make sure there isn't any flammables in the area first though.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
http://www.jeepforum.com/forum/f12/cel-check-engine-light-how-1230753/
bigbossd1030 is offline   Reply With Quote
Old 07-31-2010, 04:30 PM   #6
comptiger5000
5.9 Addict
I already hit with a heat gun (don't have a torch here), although I didn't get it glowing or anything. Didn't want to risk warping the head. I'll edit this with a pic in a minute.
Old 07-31-2010, 04:33 PM   #7
jhotrod83
You won't warp the head but you will need a torch to get it hot enough to work. A rel torch, not map gas
Old 07-31-2010, 04:35 PM   #8
comptiger5000
5.9 Addict
I'll see if I can get or borrow a torch. If not, I'll give the heat gun another try (output temp of 1050* F), and hold it for longer to see if I can get it glowing.
Bolt is in the center of the pic.
Old 07-31-2010, 04:38 PM   #9
jhotrod83
Stud extrctor is the tool you need. You should be able to get them locally. It works like cam wheels tightening it's grip the harder you turn it. It is a type of socket by the way or sometimes a series of gears
Old 07-31-2010, 04:39 PM   #10
comptiger5000
5.9 Addict
That sounds perfect! When I tried vice grips, I just couldn't get enough of a grip. I'll go buy one and let you know!
Old 07-31-2010, 06:00 PM   #11
casperbrown
1993 XJ Cherokee
small pipe wrench after a glorious soak of pb ...... stuck bolts are gods way of questioning/testing how much you really love your jeep
casperbrown is offline   Reply With Quote
Old 07-31-2010, 06:26 PM   #12
j.love
1994 ZJ
Holy fragments of metal jeep fans! you need to cover your valley! you will never get all those pieces out! try a shop vac!
WOW.
David.
94 ZJ laredo 5.2 V8 soon to be 5.9!!
In Delaware, the largest growth of population is Indian Americans, moving from India. You cannot go to a 7/11 or a Dunkin’ Donuts unless you have a slight Indian accent. I’m not joking. Joe Biden
j.love is offline   Reply With Quote
Old 07-31-2010, 07:37 PM   #13
comptiger5000
5.9 Addict
I had the valley covered while I was drilling. There's actually very little stuff (not metal, just a couple bits of leaf and such) down there for me to clean up (and I plan to hit it with the shop vac). The bright spots in the crappy cell phone pic where the light was reflecting off the oil film on the rough metal casting, making it look like metal bits.
Glock Forum
