Help - WJ front axle into ZJ? - Page 3 - JeepForum.com
 1Likes
post #31 of 34 Old 08-24-2013, 10:35 PM
jeepcreep81
This posts so old but done it!!!! Zj Wheel hubs do fit on wj knuckles, the only things I have wj are the Axel & the CV shafts, the wj Axel is longer go after the lower control arm arm brackets it will even it up, Also but a Teraflex zj high steer
Kit because if you noticed the wj Axel has it, great on the death wobble
jeepcreep81 is offline
post #32 of 34 Old 08-24-2013, 11:22 PM
1stblack97ZJ
Wow
2GPS4ME likes this.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
post #33 of 34 Old 08-28-2013, 01:32 PM
JohnnyZJ
you failed english didn't you?
07' JKUR rollin on 35s
JohnnyZJ is offline
post #34 of 34 Old 11-17-2014, 09:45 AM
a_bean43
I did the same thing, can u use the gears, carrier, etc. And rebuild the zj axle
a_bean43 is offline
Axle Shafts, Gerotor Pumps, Clutch Plates,... oh my! Is my front axle a vari-lok? 99avant WJ Grand Cherokee Forum 16 08-11-2011 09:47 PM
Front axle noise and thud coming from axle. Not u-joint or Wheel bearing. bjl95mustang ZJ Grand Cherokee Forum 0 07-12-2010 12:10 PM
4x4 front axle oil vs rear axle oil sdowney717 ZJ Grand Cherokee Forum 13 07-09-2009 11:45 PM
changing front axle shaft..axle nut lakailimited06 ZJ Grand Cherokee Forum 2 06-14-2009 09:40 AM
Replaced front axle/CV joint now a bad whining from front end? f1rz06 ZJ Grand Cherokee Forum 4 09-16-2004 03:48 AM
