Help - WJ front axle into ZJ? - Page 2 - JeepForum.com
 1Likes
post #16 of 34 Old 10-04-2010, 06:22 PM
JrMechanic
You have an axle that won't physically bolt into a ZJ, and you're worrying about brakes?
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #17 of 34 Old 10-04-2010, 07:58 PM
iluvtruenos
I've got a high pinion D30 from a Cherokee with ABS (bigger u-joint) and 3.55 gearset in Chicago.
All it needs is rotors, and calipers.
What WJ axle do you have? I'm looking for one with 3.73 gears, and a u-joint front input. I will gladly trade straight up if you've got what I need.
My Jeep is a chick magnet with reverse polarity.
2000 WJ, 4.5l, AX15, 242 D60/14b, 5.5" lift front, 7.5" rear. Ford Expedition rear coils, Ram 350 shocks, JKS, IRO Long Arms, cool Badlands flag thingy.
1987 XJ - Gone but not forgotten
iluvtruenos is offline
post #18 of 34 Old 10-04-2010, 08:22 PM Thread Starter
ADaughen
'00 WJ LP D30. 3.73:1 gear ratio. Axle doesn't have the u-joint front input. We were planning on swapping that out with the bad axle. Remember, our WJ axle doesn't have hubs. It does have the Teves(?) calipers and brackets - whatever one isn't Akebono.
Let me see what my buddy says. My dad will be going there M-W of next week for training so it might work out for a free trip.
ADaughen is offline
post #19 of 34 Old 10-04-2010, 08:37 PM
iluvtruenos
Ok, this might work. Do you know if the axle came from a quadradrive equipped Jeep?
post #20 of 34 Old 10-04-2010, 10:47 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
You got everything that sucks about a wj axle and you're going to all this trouble to make it "fit".
A zj axle with the right gears will be much cheaper in the end.
ratmonkey is offline
post #21 of 34 Old 10-05-2010, 12:17 AM
iluvtruenos
Hell, an HP D30 is an upgrade in relation to the WJ axle.
I just wish we got the HP as an option, even.
post #22 of 34 Old 11-08-2010, 06:48 AM Thread Starter
ADaughen
Well guys, due to no extra funds, and no way to go get another axle, we ended up rebuilding the ZJ axle. Fortunately the planetary was a lot more simple than we had expected.
Today is the day of truth...
ADaughen is offline
post #23 of 34 Old 11-08-2010, 06:55 AM
Technohead
What planetary? I guess you mean the spider gears? Hope you got the gears set up correctly. They don't last long otherwise.
-Eric
Technohead is offline
post #24 of 34 Old 11-08-2010, 08:52 AM
JrMechanic
You guys are retarded. Sorry, but it's true. I highly doubt you rebuilt the axle correctly, and after a month you definetly could have sold the WJ axle and at worst thrown in a few more bucks for a ZJ axle. Nobody that can afford the gas and insurance a vehicle requires is THAT broke.
post #25 of 34 Old 11-08-2010, 09:40 PM Thread Starter
ADaughen
Yep, retarded. I will admit I didn't ask the right people when V went looking for a Dana 30 originally.
Who is burning gas? The axle has been out for three months. Kinda hard to drive when there isn't rubber on the road.
If you know of any decent jobs in SE Ohio post them up. Maybe we can get it fixed properly then.
ADaughen is offline
post #26 of 34 Old 11-08-2010, 09:44 PM Thread Starter
ADaughen
The internets said it wasn't that hard. Meh, pull out, put in. Everything spins. Better than it was prior. And I was all worried about lash/backlash...
ADaughen is offline
post #27 of 34 Old 11-09-2010, 01:02 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
If you mean spiders, it is that simple. If you mean gears, it isn't even close.
post #28 of 34 Old 01-18-2011, 03:31 AM
billymac4511
Originally Posted by newfieZJ View Post
I wonder can that be compensated for by using 99-2006 TJ/XJ wheel bearings ?
I've got a WJ front axle and am considering swapping it into my TJ to get rid of the lame y-link steering.
I've read that you bolt on TJ wheel hub assy's and put a .5" spacer between the hub assy and the knuckle and that solves the issue with binding. Then replace the rotors with the ford sport trac ones.
Better brakes, no y-link gayness... I'm pleased... considering I got the WJ axle for pretty much nothing. Top it off with bad ball joints, worn out brakes and both wheel hub assy's pretty-much toast on my TJ D30. I'd say I'm doing pretty good.
Only chopping that I see I'll need to do is for the lower track bar. I'll need to trim a little smidgin out of the bottom of the passenger-side spring pan so the track bar can rotate up some when the pass-side of the front axle droops.
Webmaster and official do-gooder of interwebbish thinggies at
Also guilty for the plague, broken egg yolks and the spork.
billymac4511 is offline
post #29 of 34 Old 01-18-2011, 05:34 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
do more reading...seriously, you're not even close to doing it right.
post #30 of 34 Old 01-18-2011, 02:29 PM
NapsterZJ
You guys went at this all wrong. You could have had a beefed up axle under the ZJ.
Of course this means going out and buying a ZJ axle with almost nothing on it. You could've used the WJ knuckles for crossover steering and that would made things nice and strong. Brake upgrade from single to dual piston. Sucks you guys didn't really read up on this.
1995 ZJ Laredo 4.0 - 5 Speed swap and 4x4 conversion, JKS KOR conversion and durometer bushings, Bilstein 5100s, fixed LCAs
DD - Stock 99 WJ 4.7 QD with flo 40
NapsterZJ is offline
Axle Shafts, Gerotor Pumps, Clutch Plates,... oh my! Is my front axle a vari-lok? 99avant WJ Grand Cherokee Forum 16 08-11-2011 08:47 PM
Front axle noise and thud coming from axle. Not u-joint or Wheel bearing. bjl95mustang ZJ Grand Cherokee Forum 0 07-12-2010 11:10 AM
4x4 front axle oil vs rear axle oil sdowney717 ZJ Grand Cherokee Forum 13 07-09-2009 10:45 PM
changing front axle shaft..axle nut lakailimited06 ZJ Grand Cherokee Forum 2 06-14-2009 08:40 AM
Replaced front axle/CV joint now a bad whining from front end? f1rz06 ZJ Grand Cherokee Forum 4 09-16-2004 02:48 AM
