Help - WJ front axle into ZJ? - JeepForum.com
 1Likes
post #1 of 34 Old 10-03-2010, 09:40 PM Thread Starter
ADaughen
Anyone swap front axles before? Buddy lost a front axle off his '93 ZJ and picked up a spare off a wrecked '00 WJ. We're finding there are quite a bit of differences...
Track bar - frame mount is different. Using the old one with a new lower bushing.
Steering - the whole assembly is different. Planning on using the one off the WJ.
Steering knuckles.
Brake calipers. WJ has 2-piston NICE!
The WJ axle might also be ~1" wider than the ZJ.
The assembly we got didn't have the wheel hubs. The parts store has two part numbers between the ZJ and WJ. What we are hoping is they are interchangeable, otherwise I have to try to swap steering knuckles, etc. Project went from changing out ~10 bolts to a week long process.
ADaughen is offline
post #2 of 34 Old 10-03-2010, 10:05 PM
JrMechanic
May as well just cut all the bracketry off the WJ axle and get new ZJ/XJ/TJ brackets and spring perches. Nothing is going to be bolt up about it.
You can use the steering and outer knuckles with WJ hubs. Will need to have the hubs and rotors redrilled to the correct bolt pattern though if you want the wheels to go back on.
Sell it, and buy a high pinion D30 from a XJ, then use the steering and brakes from the WJ and have the hubs redrilled. There's no benefit to doing all that work with the WJ axle.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #3 of 34 Old 10-03-2010, 10:05 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
The wj if 3" wider and none of the bracket locations match up. Too much work for an lp30.
ratmonkey is offline
post #4 of 34 Old 10-03-2010, 10:30 PM Thread Starter
ADaughen
JrMechanic, buying another axle is not in the cards for him. Unless you want to trade front axles.
We measured they are within ~1" on width CV shaft to CV shaft. The control arms, spring perches, and track bar are spaced correctly...
Steering is set up differently, but the steering box is in the same location, so we're planning on using the full steering off the WJ.
ADaughen is offline
post #5 of 34 Old 10-03-2010, 10:57 PM
WyoZJ
1994 ZJ
I think trying to make an axle that is that different of a fit with little modification is a bad idea. You dont want to put an axle that is that much wider in the front anyway. Try to find a HP30 out of an xj. Or at least another lp30 from a zj. If he can afford brackets for this axle he can afford an xj axle if he looks a little. I picked up my HP30 for 45 bucks. Start huntin craigslist
Five speed 35" Claws, locked, some extra steel
Front and rear Trailready bumpers, roof rack, IRO Rear long arms, and HD adjustable track bar for sale
WyoZJ is offline
post #6 of 34 Old 10-03-2010, 10:59 PM
JrMechanic
No, they aren't spaced correctly, nor are the spring perches the correct size.
Apparently a working Jeep isn't in the cards for him, either.
post #7 of 34 Old 10-03-2010, 11:01 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Originally Posted by WyoZJ View Post
try to find a HP30 out of an xj. Or at least another lp30 from a zj. If he can afford brackets for this axle he can afford an xj axle if he looks a little. I picked up my HP30 for 45 bucks. Start huntin craigslist
I agree.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #8 of 34 Old 10-04-2010, 05:35 AM Thread Starter
ADaughen
Thanks guys.
ADaughen is offline
post #9 of 34 Old 10-04-2010, 05:54 AM
Technohead
JrMechanic, buying another axle is not in the cards for him . . .
Unless he wants to spend lots of money then buying another axle is the only option.
-Eric
Technohead is offline
post #10 of 34 Old 10-04-2010, 06:45 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
wms to wms on a zj is 60.5", on a wj it is 63.5".
you are not measuring from the correct spots apparently. the wj axle will need stripped of all wj brackets and zj brackets will need put on. you'll probably have a minimum of 300$ in to brackets and then you've got the totally wrong bolt pattern on the wheels to worry about and setting up the steering....get an xj, zj, or tj axle.
post #11 of 34 Old 10-04-2010, 07:13 AM Thread Starter
ADaughen
We didn't have the hubs for the WJ. So no, I wasn't measuring from the WMS. I was going to swap over the ZJ hubs before I found out Chrysler has f*d me again. The ZJ hubs would give me the correct bolt pattern and hopefully the shorter width.
I hate my life sometimes.
ADaughen is offline
post #12 of 34 Old 10-04-2010, 04:59 PM Thread Starter
ADaughen
Well, after a day of work I went back over with the tools I was missing. The hubs bolt up and engage the CV shafts. ZJ rotors won't fit on the WJ due to the rotor hat depth... I just need to find some rotors in 5x4.5 bolt pattern that are 12.01" diameter and 2.50" high...
ETA:
It looks like I will need a small spacer between the ZJ hub and WJ knuckle to center the CV shaft joint...
ADaughen is offline
post #13 of 34 Old 10-04-2010, 05:45 PM
newfieZJ
You need the JKS spacers for $21 and the rotors , from A WJ , but drilled to the ZJ bolt pattern . You will not find a match that I am aware of . Let me know if you do
JKS Manufacturing: FAB Parts
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #14 of 34 Old 10-04-2010, 06:00 PM Thread Starter
ADaughen
Thanks, those were the ones I was looking at.
Few people were running the Ford Explorer Sprot Trac rotors, but they had to have a .1" spacer between the rotor hat and hub. Redrilled rotors appear to be the better bet.
I am seeing where the missing 2" is coming from, now. >_<
ADaughen is offline
post #15 of 34 Old 10-04-2010, 06:22 PM
newfieZJ
I wonder can that be compensated for by using 99-2006 TJ/XJ wheel bearings ?
1995 Orvis build
1988 MJ build
newfieZJ is offline
Axle Shafts, Gerotor Pumps, Clutch Plates,... oh my! Is my front axle a vari-lok? 99avant WJ Grand Cherokee Forum 16 08-11-2011 08:47 PM
Front axle noise and thud coming from axle. Not u-joint or Wheel bearing. bjl95mustang ZJ Grand Cherokee Forum 0 07-12-2010 11:10 AM
4x4 front axle oil vs rear axle oil sdowney717 ZJ Grand Cherokee Forum 13 07-09-2009 10:45 PM
changing front axle shaft..axle nut lakailimited06 ZJ Grand Cherokee Forum 2 06-14-2009 08:40 AM
Replaced front axle/CV joint now a bad whining from front end? f1rz06 ZJ Grand Cherokee Forum 4 09-16-2004 02:48 AM
