Help, water leaks from air outlet... - JeepForum.com
post #1 of 4 Old 09-02-2003, 08:13 PM Thread Starter
sakom39
Just found the water (clear) keeps seeping out of the floor airflow outlet under passenge seat when the car (94' GC) is running. What may be the problem? Any thought welcome. Thanks.
Kevin
sakom39 is offline
post #2 of 4 Old 09-02-2003, 09:24 PM
MaineZJ
MaineZJ's Avatar
Got the AC running, don't know if that would leak inside.
MaineZJ is offline
post #3 of 4 Old 09-02-2003, 09:39 PM Thread Starter
sakom39
When the AC is running, the leak is extremely obvious (~50ml for 20min). I think it is the water that suppose to discharge from AC system, coz I no more see that kind of water drip down to the ground again. But, I really don't know how it ends up in the air outlet instead.
Kevin
sakom39 is offline
post #4 of 4 Old 09-02-2003, 10:07 PM
Jillie
Jillie's Avatar
i did a search and came up with this http://www.jeepforum.com/forum/f13/93-ac-drain-48313/
hope that helps...
97 I6 ZJ
K&N FIPK
Flowmaster muffler
Jillie is offline
Commander Door/Windshield Water Leaks chriswcarson WK Grand Cherokee & XK Commander Forum 1 08-09-2009 05:39 PM
2005 GC leaks water snood WK Grand Cherokee & XK Commander Forum 3 03-08-2008 06:41 AM
Do I need a new Water Pump? Bad Leaks Getting Worse(Pics) Ruffy ZJ Grand Cherokee Forum 24 06-17-2005 09:24 PM
Water Leaks in a '04 JGC Ltd. KC8RXQ ZJ Grand Cherokee Forum 3 08-26-2004 03:21 PM
Help! AC leaks water inside!! jdpaysnoe ZJ Grand Cherokee Forum 5 05-27-2004 02:53 PM
