Help w/ CIL - JeepForum.com
post #1 of 3 Old 09-09-2004, 09:52 AM Thread Starter
Littlefoot
Help w/ CIL
Help! We have a 2001 late model Jeep Grand Cherokee. Recently the Check Engine Light came on. When it first came on I was driving around 60 mph. It was blinking and the engine was rough. After it was shut off the light remained on and it smoothed out. We had it serviced. They said it was a misfire on one of the cylinders. They found a spark plug to be bad, so they replaced all of them. It worked fine for a about two weeks and then the same problem resurfaced.
Next they replaced the coil. This fixed the problem for about a week. The problem came back worse. We were going around 72 mph. When we started up an incline you could tell there was a lose of power. The Jeep reacted with bucking.
This time when we took it in the CEL wasn't on. They can't get it to react the same way.
We already are out quite a bit of money. Any help would be greatly appreciated.
Thanks
Littlefoot is offline
post #2 of 3 Old 09-10-2004, 10:47 AM Thread Starter
Littlefoot
It's been 4 days now and they still haven't fixed it. I like driving the Wrangler, but I miss the luxury of the Cherokee. Any help would be greatly appreciated.
post #3 of 3 Old 09-10-2004, 12:08 PM
Meerkat
FWIW, in my experience, bucking is usually caused by a fuel issue. Either water in the gas or not enough gas getting to the cylinder.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
