Help with Transmission Slipping - JeepForum.com
post #1 of 4 Old 09-11-2003, 07:55 AM Thread Starter
greasefingers
greasefingers's Avatar
1994 ZJ
My 94 GC with 160K miles on it is having problems. The transmission is slipping at low and high speeds. I dropped the trans cover and replaced the filer 10K ago. Has anyone ever adjusted the two band adjustments? Am I in for a new tranny?
It's a 4.0 L QuadraTrac with automatic transmission.
greasefingers is offline
post #2 of 4 Old 09-15-2003, 09:32 AM
automan25
Obviously the first thing you'll want to do is adjust the bands and see if that cures the problem. It's a whole lot easier (and cheaper) than replacing your transmission. Get a service manual for the proper adjustment procedure. You'll probably need a couple of new tools. Namely an inch/lbs. torque wrench and a funky curved extension to reach the front band adjustment screw. (read the instructions that come with the torque wrench to find out how to use an extension properly with a torque wrench)
Don't wait too long to do this. When your transmission is slipping against the bands, it is wearing out the bands and generating a lot of extra heat. Once the bands are worn out completely no amount of adjustment will cure the problem.
1993 ZJ Limited 5.2 - no mods - Red with Gold (what were they thinking) trim.
automan25 is offline
post #3 of 4 Old 09-16-2003, 05:06 PM Thread Starter
greasefingers
1994 ZJ
thanks
Thanks for the reply. I tried to adjust/check the bands a couple years back, but I failed due to the funky curved wrench that you mentioned. I will search for one first before attemping this :-)
post #4 of 4 Old 09-16-2003, 06:39 PM
RockPaws
RockPaws's Avatar
How is the fluid level while in neutral? Make sure its correct, this trans can be tempermental with incorrect level. I would also drop the pan and change the filter again. Check for metal in the pan.
My 97' Grand transmission went out at 60K. The over drive unit is the part that usually fails (and it did) due to lack of oil to it(metal in the pan too). The oil passage is too small and needs to be drilled out to improve oil flow.
If it does need a rebuild have them install more clutch disc's in the over drive unit. Their are 2 clutch packs, one can take one more and the other 2-3 more.
If you want a transmission shift kit. I have a TransGo kit for the JGC auto trans. I bought it for a customer and did not use it. I put it in our JGC at overhaul... very nice shifting trans! Email me.
01' Jeep TJ (Jeep #5)
3.5 RE Custom SuperFlex, Raingler, Kilby, Currie, Banks, Borla, American Racing, Custom mods, Always more in the works.
RockPaws is offline
CRD WK transmission slipping mungpat WK Grand Cherokee & XK Commander Forum 9 01-28-2009 10:15 AM
transmission slipping 56BelAir ZJ Grand Cherokee Forum 6 08-28-2008 04:08 PM
HELP!!! 5.9 transmission slipping??? ponsta ZJ Grand Cherokee Forum 7 06-21-2006 05:00 PM
96 GC transmission slipping? jds4218 ZJ Grand Cherokee Forum 1 02-09-2005 04:40 AM
transmission slipping rhong ZJ Grand Cherokee Forum 0 08-13-2002 01:22 PM
