Help with trans question. - JeepForum.com
post #1 of 3 Old 08-16-2009, 04:38 AM Thread Starter
sadass
I was driving on Interstate today and at @ 68 mph wih the C.Control set. with 4.56s , the rpms were @ 2,300.
As I was halfway up a long grade, The trans downshifted and would not go back into Overdrive for the remainder of the trip. I noticed that the Led that is for the Momentary Overdrive off switch was illuminated and would not go out. I pulled over , Inspected and even disconnected the Bat.
Led for the overdrive lock out would not go out when power was retuned.
The trans acted normal. after stopping it when to first second and thrird with out issue. The problem is that the led would not go out and it would not shift to overdrive. My rpms were over 3,000 doing 55mph.
Ok here is some more info. when the jeep cooled down for an Hour. the overdrive lock out led and switch worked normal. then 10 min later the led came on with out my aid. again I lost the overdrive .
I let it sit at work for a few hours, Now it is fine but I did not drive more than 15 min. \\ the switch trans and led work normal .
How does overdrive lock out circuit work? what would cause the circuit to activate automaticlly
Any info to guide me with my troubleshooting would be great.
5NineZJ,35mtr/k IRO 7" LA F/R Detroit F/HP-4.56 R/Aussie 44A. ARB Snorkel/JRC Sliders/ Protofab w/9500S./Bushwhackers. Novak242 TCcable.
sadass is offline
post #2 of 3 Old 08-16-2009, 03:34 PM
elmer_fud
I think there is a tempature sensor in the transmission that us used for the lockout. If the transmission gets hot I think it locks out overdrive. I though it also turned on a light on the dash when the transmission was hot.
if you don't have a tranny cooler it would probally be a good idea to add one
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #3 of 3 Old 08-16-2009, 06:07 PM Thread Starter
sadass
Thanks, I think you are right. That would all add up as to when it happend and why it is not faulting now.
sadass is offline
07 XK 4.7 Trans question TSB MISahara WK Grand Cherokee & XK Commander Forum 2 01-28-2010 10:01 AM
97 GC 42re trans question ezrider327 ZJ Grand Cherokee Forum 19 06-25-2008 06:47 PM
WJ Trans question jeepmann45 ZJ Grand Cherokee Forum 7 01-31-2008 10:07 AM
Trans Question li'l jeep ZJ Grand Cherokee Forum 3 08-18-2007 06:29 PM
trans question biggator64 ZJ Grand Cherokee Forum 1 03-02-2006 06:07 AM
