Help Techs: Running Rich at Hot Startups - JeepForum.com
post #1 of 11 Old 06-01-2006, 04:57 AM Thread Starter
Scott98GC
My '98 GC 4 liter is running rich and stumbling at hot startups. It's okay if its only been shut off for a couple of minutes, but for longer periods or unless it's fully cooled off it will buck and stumble until it cleans itself out. If I start it and rev it a couple of times, it will clean out and run fine.
I don't want to go to the dealer and have him throw parts at it until a cure is found. I'm thinking it may be a sensor telling the computer that the engine is cold and therefore telling the engine to run too rich.
Any ideas?
Scott98GC is offline
post #2 of 11 Old 06-01-2006, 06:13 AM
greasefingers
greasefingers's Avatar
1994 ZJ
You would need to know if she storing any codes. Even then it is no guarantee that a sensor has not drifted. How old is your oxygen s sensor? I hear 1998 model has trouble retrieving codes by the manual method? You could try this: Extracting Fault Codes OBDII (with digital odometer display)
Newer (OBDII) models - Put the key into the ignition, push down the odometer reset button, then turn the key to RUN with your finger on the button - and then release the button. The odometer will go through 1111111 through 999999, and then display the car's serial number. It will then show the error codes
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #3 of 11 Old 06-01-2006, 06:37 AM Thread Starter
Scott98GC
Thanks for the reply.
Mine won't display codes using the above method... what's the other method?
post #4 of 11 Old 06-01-2006, 06:49 AM
greasefingers
1994 ZJ
Extracting Fault Codes:
Turn the ignition switch ON, OFF, ON, OFF, ON and observe the CHECK ENGINE LIGHT. The CHECK ENGINE LIGHT should begin to flash a series of codes. The flashes will be separated by short and long pauses. The long pauses separate the "ones" and "tens" positions, and each code from the next. A code 55 will be displayed at the end of the test.
Cheers Steve
post #5 of 11 Old 06-01-2006, 06:52 AM
greasefingers
1994 ZJ
You cycle the key to on/run and not start. Do it quickly.
Cheers Steve
post #6 of 11 Old 06-01-2006, 08:11 AM Thread Starter
Scott98GC
I couldn't get it to go into code display mode. Mine must be one of those '98's that needs a code reader.
post #7 of 11 Old 06-01-2006, 08:14 AM
greasefingers
1994 ZJ
Yea that seems to have been reported here a few times. I do not know why that model year is such a PITA.
Cheers Steve
post #8 of 11 Old 06-01-2006, 08:15 AM Thread Starter
Scott98GC
It's got 100,000 miles on it now. I've only had it a year, but according to the previous owner's service record, it's never had a new O2 sensor.
post #9 of 11 Old 06-01-2006, 08:17 AM
greasefingers
1994 ZJ
The v8 will also run rich if the ERG valve is stuck closed, as this dilutes the gas mixture in the cyl and lowers the combustion temp.
I would at the very least, pull a plug and examine the color.
Cheers Steve
post #10 of 11 Old 06-01-2006, 07:23 PM Thread Starter
Scott98GC
Has anyone else had these symptoms?
post #11 of 11 Old 06-01-2006, 08:05 PM
GreenDean
GreenDean's Avatar
Mine does this in the heat. I dont worry to much.. just the old engine blues.
GreenDean is offline
Jeep is running rich and misfiring, sometimes. impuresoul2k3 ZJ Grand Cherokee Forum 11 09-15-2009 09:23 PM
Rich running/backfiring issues with my Grand Cherokee Country Boy ZJ Grand Cherokee Forum 31 04-27-2008 10:33 AM
95 GC V8 running rich camosilver ZJ Grand Cherokee Forum 1 09-17-2007 02:05 PM
Running rich while towing, 96 Grand Cherokee mcfadds ZJ Grand Cherokee Forum 10 08-17-2007 02:48 PM
Running rich/missing Choff ZJ Grand Cherokee Forum 8 02-28-2004 09:32 PM
