Help with surge please. - JeepForum.com
post #1 of 22 Old 07-19-2013, 08:01 PM Thread Starter
funforfree
Hi all. I have a 95 grand Cherokee it has a v8 in it. When I hit the gas past 2k rpm it surges. If I mash it to the floor it really surges and bucks hard. After a little drive it will loose all power and will only idle sounds like a bad miss. As soon as I turn it off and back on its fine again for another mile or two then same process. When I hit it hard it's like it hits a rev limiter trans shifts smooth ect. Tried new plugs, wires, cap, rotor, crank position sensor, and cat converter. Am very stumped. Check engine never comes on.
funforfree is offline
post #2 of 22 Old 07-19-2013, 08:04 PM
Siva283
Iac map or o2. There are ways to test the sensors with a meter but I don't know the readings for your year. Also did you reset tge ecm after any of these changes
Sent from my SPH-L300 using JeepForum
Ask me how I know...
Siva283 is offline
post #3 of 22 Old 07-19-2013, 08:06 PM Thread Starter
funforfree
Yes after I did the crank sensor I did.
post #4 of 22 Old 07-19-2013, 08:12 PM
Siva283
How about fuel filter sounds like it is starving for gas. What's the condition of the distributor and shafts. If there is any real play when you tey to turn the rotor with engine off it can cause thw timing to be off. The higher the rpm the worse it could be off. Does it do this when the engine is cold and at operating temp?
Siva283 is offline
post #5 of 22 Old 07-19-2013, 08:56 PM Thread Starter
funforfree
Mostly at operating temp. When it starts to break up I pull over turn it off and restart it hit the gas a few times it smells like soot and runs fine again for a mile or so.
post #6 of 22 Old 07-19-2013, 09:03 PM
ZeeJay1997
Is it surging or missing?
If it starts missing under load, suspect the cat is stopped up.
IAC only affects idle
ZeeJay1997 is offline
post #7 of 22 Old 07-19-2013, 09:26 PM Thread Starter
funforfree
It idles good. Sounds like a miss like it is choking out. Have to pump the gas fast to keep it going. But if I shut it off it runs fine again when I restart it.
post #8 of 22 Old 07-19-2013, 10:28 PM
ZeeJay1997
A lot of times these type issues will be caused by low manifold vacuum due to leaks or excess back pressure that passes around valve seats under load.
Are you hearing the valves rattle before it starts missing?
post #9 of 22 Old 07-19-2013, 11:16 PM
ozzy_2_me
1994 ZJ
just out of curiosity in what condition are the plug wires and spark plugs? oh and check out the egr.
ozzy_2_me is offline
post #10 of 22 Old 07-20-2013, 06:10 AM
JS97ZJ
Clogged cat.
JS97ZJ is offline
post #11 of 22 Old 07-20-2013, 07:16 AM
Siva283
Originally Posted by JS97ZJ View Post
Clogged cat.
He jusr replaced the cat.
Siva283 is offline
post #12 of 22 Old 07-20-2013, 07:21 AM
Rich93ZJ
Did you replace you crank sensor with a Mopar unit or one from the autoparts store? Mopar ONLY on the crank sensor. The cheap aftermarket junk will do weird stuff like you are describing.
Rich93ZJ is offline
post #13 of 22 Old 07-20-2013, 08:52 AM Thread Starter
funforfree
Yes I did get a mopar. I just noticed that the vacuum line to the map sensor has a rubber cap on it no line is this correct?
post #14 of 22 Old 07-20-2013, 03:42 PM
Siva283
No the map should have a vac line going to it
Siva283 is offline
post #15 of 22 Old 07-20-2013, 04:38 PM
Rich93ZJ
^^This^^. Should also have a check valve in line with it
Rich93ZJ is offline
