Help Stuck Transfer Case!!!! - JeepForum.com
post #1 of 11 Old 03-29-2005, 04:15 PM Thread Starter
1997zj
help i shifted from 2wd to 4 full and got stuck in part time....i then tried shifting out of it and got stuck in 4 lo... this thing is bound up real tight wont move at all linlage is all together but just wont sjift!!!help is aamco a good place to get it fixed
1997 Jeep Grand Cherokee Laredo i6
235/75/15 bfg's all terrains
plenty of trail damage
Future upgrades...
31x10.5 bfg all terrains
3 inch rustys suspension lift
steering stabilizer (any suggestions)
jks quick disco's
1997zj is offline
post #2 of 11 Old 03-29-2005, 04:40 PM
porrsher
1994 ZJ
tc
Have you shifted the tc before or is this your first time?
porrsher is offline
post #3 of 11 Old 03-29-2005, 04:48 PM Thread Starter
1997zj
deff not the first time i shifted and almost heard like a chain sound...like your 10 speed bike used to make when the chain fell off now its stuck
Future upgrades...
jks quick disco's
1997zj is offline
post #4 of 11 Old 03-29-2005, 05:16 PM
porrsher
1994 ZJ
chain
Sorry dude for the last question,
didn't read your signature till now. I was going to tell you follow directions on shifting, have no other ideas other than you chain might have broken.
porrsher is offline
post #5 of 11 Old 03-29-2005, 09:05 PM Thread Starter
1997zj
ok crazy issue now so i messed around with the linkage and it is now out of 4 lo...BUT!! now it seems the gears moved up and are out of alignment...like the frist gear is part time>full time>neutral> 4lo...it seems as if 2wd is no longer there
Future upgrades...
jks quick disco's
1997zj is offline
post #6 of 11 Old 03-30-2005, 01:05 AM
Swamp Boy
Swamp Boy's Avatar
Have you tried adjusting your shift linkage and spraying the crap out of it with WD 40 or something..
Find your shift linkage and loosen the adjuster nut on it then follow the linkage to the t case and take a 14mm wrench and turn the nut counter clockwise.. See if that gets you into 2WD.. Then put the handle inside in 2 and tighten it back up..
Spray it and try to shift thru the gears...
Just another soccer moms Grocery getter....
Swamp Boy is offline
post #7 of 11 Old 03-30-2005, 06:54 AM Thread Starter
1997zj
ooo yea i wd40'd everything and tried adjusting linkage but still cant get into 2!?!
Future upgrades...
jks quick disco's
1997zj is offline
post #8 of 11 Old 03-30-2005, 09:08 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Loosen the linkage, and get underneath and use big pliers to move the shift lever on the TC to the 2wd position. If you can't get it into 2wd that way, there's trouble with the TC.
HighLonesome is offline
post #9 of 11 Old 03-30-2005, 04:04 PM
Swamp Boy
Swamp Boy's Avatar
What he said...
post #10 of 11 Old 06-20-2011, 08:13 PM
gsxr07
Ok I know this post is old but I got stuck 2 tracking the other day and since then I have a funny "bearing" Type sound coming from the TC and now it won't shift into 4.. And seems like it's not in 2 either.. I tried moving all the linkage and lubed it up real good, everything moves good except for the link right at the TC, it doesn't move AT ALL.. I tried to turn it with giant 2' channel locks but nothing..
gsxr07 is offline
post #11 of 11 Old 07-10-2011, 04:55 PM
tanner1025
i have the same problem just recently dropped 249 case out resealed all up good. it seems as if im in a different gear now. i cant get it in 4 wheel lo my light wont come on tried manually shifting it and its jammed up good
tanner1025 is offline
transfer case stuck in 4wd? lateralus3 ZJ Grand Cherokee Forum 3 07-18-2009 09:07 PM
Transfer case lever stuck fzillman ZJ Grand Cherokee Forum 14 08-15-2007 07:09 AM
stuck t-case bolts. Derek33 ZJ Grand Cherokee Forum 7 07-24-2007 01:06 PM
'93 ZJ stuck t-case shifter Crispin ZJ Grand Cherokee Forum 7 01-04-2007 02:32 PM
i think my transfer case is stuck S10Eater ZJ Grand Cherokee Forum 6 10-14-2006 12:41 PM
