-   -   Help Stuck Transfer Case!!!! (http://www.jeepforum.com/forum/f13/help-stuck-transfer-case-149728/)
1997zj 03-29-2005 04:15 PM
help i shifted from 2wd to 4 full and got stuck in part time....i then tried shifting out of it and got stuck in 4 lo... this thing is bound up real tight wont move at all linlage is all together but just wont sjift!!!help is aamco a good place to get it fixed
porrsher 03-29-2005 04:40 PM
tc
Have you shifted the tc before or is this your first time?
1997zj 03-29-2005 04:48 PM
deff not the first time i shifted and almost heard like a chain sound...like your 10 speed bike used to make when the chain fell off now its stuck
porrsher 03-29-2005 05:16 PM
chain
Sorry dude for the last question,
didn't read your signature till now. I was going to tell you follow directions on shifting, have no other ideas other than you chain might have broken.
1997zj 03-29-2005 09:05 PM
ok crazy issue now so i messed around with the linkage and it is now out of 4 lo...BUT!! now it seems the gears moved up and are out of alignment...like the frist gear is part time>full time>neutral> 4lo...it seems as if 2wd is no longer there
Swamp Boy 03-30-2005 01:05 AM
Have you tried adjusting your shift linkage and spraying the crap out of it with WD 40 or something..
Find your shift linkage and loosen the adjuster nut on it then follow the linkage to the t case and take a 14mm wrench and turn the nut counter clockwise.. See if that gets you into 2WD.. Then put the handle inside in 2 and tighten it back up..
Spray it and try to shift thru the gears...
1997zj 03-30-2005 06:54 AM
ooo yea i wd40'd everything and tried adjusting linkage but still cant get into 2!?!
HighLonesome 03-30-2005 09:08 AM
Loosen the linkage, and get underneath and use big pliers to move the shift lever on the TC to the 2wd position. If you can't get it into 2wd that way, there's trouble with the TC.
Swamp Boy 03-30-2005 04:04 PM
What he said...
gsxr07 06-20-2011 08:13 PM
Ok I know this post is old but I got stuck 2 tracking the other day and since then I have a funny "bearing" Type sound coming from the TC and now it won't shift into 4.. And seems like it's not in 2 either.. I tried moving all the linkage and lubed it up real good, everything moves good except for the link right at the TC, it doesn't move AT ALL.. I tried to turn it with giant 2' channel locks but nothing..
tanner1025 07-10-2011 04:55 PM
i have the same problem just recently dropped 249 case out resealed all up good. it seems as if im in a different gear now. i cant get it in 4 wheel lo my light wont come on tried manually shifting it and its jammed up good
The time now is 05:43 AM.
