Help with replacing heater core on my 01 Jeep grand chreokee - JeepForum.com
post #1 of 11 Old 01-06-2009, 03:37 PM Thread Starter
neodamonkey
So i have the instrument panel off..... can someone help me with getting to the actual heater core and replacement......first time workng on hvac systems....,. first thing i guess would be getting it out
neodamonkey is offline
post #2 of 11 Old 01-06-2009, 04:01 PM Thread Starter
neodamonkey
When i say i have the instrument panel off i am down to this......do i need to take this piece off as well?
post #3 of 11 Old 01-06-2009, 04:29 PM
merlinTec
merlinTec's Avatar
O.M.G you have well over stripped this, the dash comes out complete you didn’t have to strip it like that but too late now, any way that’s not helping you sorry. Yes you need to take the rest out. Bolt up behind where the steering shaft was, 3 bolts down each side A pillar, 2 bolts where the glove box was, bolt in the trans tunnel. Hole dash should then come out. And leave behind the heater. Looks like you have unplugged all the electrics but just have a look around as the dash comes out under the heater box could still be connected. I also remove the shifter. Will make it easy to rebuild I suppose as you can put the dash mostly back together out of the vehicle.
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #4 of 11 Old 01-06-2009, 05:07 PM Thread Starter
neodamonkey
I didnt have the dash cover off until i spent an hour trying to find out what was holding it in....the passanger side is completly free however the driver side is still being held in by something
post #5 of 11 Old 01-06-2009, 05:11 PM Thread Starter
neodamonkey
Seems like something is holding it in right around that area....thats why i took the cover off was to try to get a better view of what i could be missing...only i still have not found it lol
post #6 of 11 Old 01-07-2009, 01:49 AM
merlinTec
merlinTec's Avatar
yet bolt up under get on you back and look up where the steering was
post #7 of 11 Old 01-07-2009, 02:28 AM
AgitatedPancake
yeah there is a vertical nut you have to remove up above where your brake pedal mounts to the firewall, its definately akward. I actually have mine completely apart right now also
*EDIT* and Merlin, how non-stripped does it have to be? Console stay in? Or do you mean removing the dash pad and that dash plastic peice at the same time?
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #8 of 11 Old 01-07-2009, 08:55 AM
JG_Canuck
Yeah, unless you have your head right at the brake pedal and look up, you won't see the hidden nut that's holding the rest in place.
The console has to come out, and the dash cover and the plastic piece come out as a single unit.
Canadian Jeep Club Member Forty-Two
JG_Canuck is offline
post #9 of 11 Old 01-07-2009, 10:56 AM
merlinTec
merlinTec's Avatar
Hi
Consol out yes, but radio, heater panel, dash pad and instrument cluster can all stay in.
Regards,
Merlin
post #10 of 11 Old 04-08-2009, 08:54 PM
little_Jeep
Is there a good write up on replacing the heater core and/or AC Evap in a 2000 WJ Laredo? I understand that the dash will come out as a unit but that there are some almost impossible bolts/nuts to locate.
little_Jeep is offline
post #11 of 11 Old 04-08-2009, 09:03 PM
jeeposaurus1
Here is a write up on WJJeeps.
Wheeler-'93 ZJ 4.0
Daily Driver- '02 WJ 4.7 Quadradrive
jeeposaurus1 is offline
Replacing Heater Core on 99 Jeep Grand Cherokee ralphlassiter ZJ Grand Cherokee Forum 5 07-05-2014 11:34 PM
Replacing heater core ojay83 ZJ Grand Cherokee Forum 1 11-16-2009 06:30 AM
Other option to replacing heater core? gmp211 ZJ Grand Cherokee Forum 13 10-09-2009 02:38 PM
Looking for detailed how to on replacing heater core/Blend doors neodamonkey ZJ Grand Cherokee Forum 5 01-06-2009 02:35 PM
Replacing heater core jeepwillies ZJ Grand Cherokee Forum 0 09-18-2003 08:50 AM
