Help with rear hatch - JeepForum.com
post #1 of 6 Old 07-18-2013, 08:58 AM Thread Starter
Laceyrww3
So, I had a problem with my getting my hatch door open. I read a few of the other threads and this solution worked to open the door: I have to hit unlock on the door a few times in a row and it frees up the hatch, then I have to push on the hatch while I pull the handle to open it. It takes a few times and I look stupid while I do it. My question is there a way to fix the door so it works normal. I'm not really sure why I have to do this dance every time I need to open the door... Do I need to buy a new something or WD-40 something else? Help please.
Laceyrww3 is offline
post #2 of 6 Old 07-18-2013, 09:33 AM
OCDComputing
I'm also curious about this as I have the same sort of problem. For me though, if I press on the plastic piece around the handle and then pull the handle it opens. Very annoying!
OCDComputing is offline
post #3 of 6 Old 07-18-2013, 09:40 AM
lolo415
over a period of time those pieces wear out i took mine apart and put some little washers in and got a nice tight fit opens like a charm now
lolo415 is offline
post #4 of 6 Old 07-18-2013, 10:06 AM
dnuccio
you could maybe adjust the striker out a little bit, but that might cause the door to rattle
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #5 of 6 Old 07-18-2013, 08:17 PM
OCDComputing
Little washers where exactly? There seems to be a few adjustable areas. I've got the back cover off right now because the rear wiper has decided to crap the bed.
Cheers,
Cameron
post #6 of 6 Old 07-18-2013, 09:11 PM
moldeck
There are rubber stoppers on each side. try screwing them in some so there is not as much tension on the lock itself. I just ran mine out some because the door was rattling over bumps in the road. Its a 13mm wrench.
moldeck is offline
hatch
