-   -   Help with rear hatch (http://www.jeepforum.com/forum/f13/help-rear-hatch-1550519/)
Laceyrww3 07-18-2013 09:58 AM
So, I had a problem with my getting my hatch door open. I read a few of the other threads and this solution worked to open the door: I have to hit unlock on the door a few times in a row and it frees up the hatch, then I have to push on the hatch while I pull the handle to open it. It takes a few times and I look stupid while I do it. My question is there a way to fix the door so it works normal. I'm not really sure why I have to do this dance every time I need to open the door... Do I need to buy a new something or WD-40 something else? Help please.
OCDComputing 07-18-2013 10:33 AM
I'm also curious about this as I have the same sort of problem. For me though, if I press on the plastic piece around the handle and then pull the handle it opens. Very annoying!
lolo415 07-18-2013 10:40 AM
over a period of time those pieces wear out i took mine apart and put some little washers in and got a nice tight fit opens like a charm now
dnuccio 07-18-2013 11:06 AM
you could maybe adjust the striker out a little bit, but that might cause the door to rattle
OCDComputing 07-18-2013 09:17 PM
Little washers where exactly? There seems to be a few adjustable areas. I've got the back cover off right now because the rear wiper has decided to crap the bed.
Cheers,
Cameron
moldeck 07-18-2013 10:11 PM
There are rubber stoppers on each side. try screwing them in some so there is not as much tension on the lock itself. I just ran mine out some because the door was rattling over bumps in the road. Its a 13mm wrench.
The time now is 02:06 PM.
