Help with pulled codes 94 ZJ 4.0L - JeepForum.com
post #1 of 5 Old 05-07-2009, 10:28 AM Thread Starter
littlefdl
1994 ZJ
Pulled my codes via check engine blink, code 35(idle switch motor fault) and code 42which can be A)Automatic shutdown relay circuit open or shorted B)Fuel pump relay control) C)Fuel level unit-no change over miles D)Z1 voltage missing when autoshutdown circuit engaged.
Im having two problems.1) Every once in awhile it wont start, its getting spark but wont turn over, after about 6 attempts it will turn over. 2) Maybe once a week When i come to a complete stop, then proceed to accelerate it will sputter for about 10 seconds like its running out of gas then will finally pick up.
Any help diagnosing these codes would be greatly appreciated.
littlefdl is offline
post #2 of 5 Old 05-07-2009, 11:13 AM
rm2001wj
rm2001wj's Avatar
I believe that your code 35 should be a 25 if it is to refer to idle control.
Since both of your problems seem to intermittent, it will be hard to tell exactly what to fix. However, replacing the idle air control valve, located on the throttle body, is indicated by the code 25.
A slightly more complete description of 42 is:
An open or shorted condition detected in the auto shutdown relay circuit. An open condition detected in the ASD relay output circuit. An open or shorted condition detected in the fuel pump relay control circuit. An open circuit between PCM and fuel gauge sending unit. Circuit shorted to voltage between PCM and fuel gauge sending unit. No movement of fuel level sender detected.
The ASD relay provides power to several circuits, and if it were me, I would replace that relay.
rm2001wj is offline
post #3 of 5 Old 05-07-2009, 11:26 AM Thread Starter
littlefdl
1994 ZJ
Thx for the reply.I was leaning towards just replacing the ASD relay and the fuel pump relay. Intermittent problems are aggravating.
post #4 of 5 Old 05-07-2009, 12:04 PM Thread Starter
littlefdl
1994 ZJ
Do u think its necessary to replaced the ASD and FUEL relay?? I might just be ok just replacing the ASD?
post #5 of 5 Old 05-07-2009, 01:28 PM
rm2001wj
rm2001wj's Avatar
The output from the ASD relay supplies power for the fuel pump relay. Just do the ASD first.
rm2001wj is offline
pulled some codes - help please BLACKzj52 ZJ Grand Cherokee Forum 19 06-18-2008 10:39 AM
pulled some codes BLACKzj52 ZJ Grand Cherokee Forum 1 09-07-2007 02:22 PM
pulled codes teenwolf1393 ZJ Grand Cherokee Forum 3 06-11-2007 03:31 AM
Pulled AZC Codes JayIV ZJ Grand Cherokee Forum 6 09-29-2006 06:55 AM
Pulled codes on my ZJ... haus409 ZJ Grand Cherokee Forum 7 05-04-2005 05:02 PM
