Quantcast Help Please, turn signal reminder, right headlight dim - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Help Please, turn signal reminder, right headlight dim
Old 10-27-2009, 06:56 AM   #1
hartrobinson
My wife's car has had a intermittent problem for a while. While driving, the "turn signal on" reminder comes on at the information center in front of the sunroof. The signal will not be on at the time. In a separate but hopefully related issue, I was replacing a brake light on the right rear this weekend and decided to check the headlights as I was to take the car through inspection tomorrow. Low beams seemed to work fine, when I switched to high beams, the right light turned off. I pulled the assembly (replaced entire assembly due to foggy lenses approx 6 months ago) and changed out the high beam bulb. Once reinstalled the problem was still the same. High beam nonexistent on right side. I didn't notice until this point but the low beam light was very dim. If I looked at the light the high beam bulb was glowing when the low beams were on. If I switched to high beam, they both turn off. It's been suggested that all of these are being caused by a bad turn signal switch. Could it be the relay i hear click (under the panel below the steering wheel) when I turn the lights on? This jeep is equipped with the auto headlights integrated turn signal switch. thanks!
hartrobinson is offline   Reply With Quote
Old 10-27-2009, 08:30 AM   #2
LordHobbit
Captain Awesome
LordHobbit's Avatar
clean up grounds. If your headlight grounds are slightly corroded they might not work. check wiring for shorts.
93 ZJ 188k 4.0l, IRO 5.5" springs, hpd30 and 8.8 in the shed, waiting on clayton long arms, 4.88 gears, locker ...
If at first you don't succeed, use more speed.
Originally Posted by RhinofiedZJ View Post
Famous last words, "If you had a locker you would of made it"....:D
LordHobbit is offline   Reply With Quote
Glock Forum
