help please! I'm at a loss. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > help please! I'm at a loss.
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 07-16-2002, 01:20 PM   #1
uwgKA
heres the deal. I have a roar from the front diff somewhere. I have done the search and read "diagnosing front end noise" at randy's ring and pinion.
at first I thought it was the pinion but now I am not so sure. I replaced the driverside axleshaft just before the roaring started due to a busted cv. the roaring has got progressively louder so I tried changing out the axleshaft again just for ****s and giggles. well, with another new axleshaft the roaring was cut almost in half but was still there.
heres my question. did pepboys give me the wrong axleshaft and cause pressure to be put on something in the diff. would an axleshaft that is a litle too long or the wrong size put pressure on the carrier.
the roar is definitly more prominent from the drivers seat
what do yall think it is? carrier bearings? or pinion bearings? I am at a loss.
btw 95 ZJ QT stock
uwgKA is offline   Reply With Quote Quick reply to this message
Unread 07-16-2002, 10:12 PM   #2
boosh
i have the same thing on mine i have a ? does yours only do it whne you accelerate or all the time ? i just droped it of at the mechanic to see what they say it is
98 jeep grand cherokee limited very nice a new project in the making "Love the jeep"
k&n gereation 2 intake and killer sound system! So far
*just totaled* 93 jeep grand cherokee
k&n gereation 2 intake, gibson exhust, low temp thermostat and killer sound system
boosh is offline   Reply With Quote Quick reply to this message
Unread 07-17-2002, 08:56 AM   #3
uwgKA
yeah at first it did.
it also roared at constant speed.
the roaring would go away or get significantly less under decel.
if you get it figured out let me know. I am taking mine in fri.
Unread 07-18-2002, 10:14 PM   #4
boosh
i have a big problem the front axle and transfercase both need major work equaling up to a couple grand
Unread 07-19-2002, 02:14 PM   #5
uwgKA
does yours have the QT
Unread 07-19-2002, 02:44 PM   #6
boosh
yeathey said it hit something and moved it
