HELP!!!! please i need help asap!! - JeepForum.com
post #1 of 14 Old 05-16-2009, 03:29 PM Thread Starter
ECMUDSLINGER
I have a 1993 jeep grand wagoneer with a 5.2liter v8 and i let my friend help with my plug wires and they are miss crossed some where!!! I need the firing order or a diagram of the distributor cap with the wires...please help...thanks ECMUDSLINGER>>>>
ECMUDSLINGER is offline
post #2 of 14 Old 05-16-2009, 03:43 PM
rooster51
http://autorepair.about.com/library/....htm:thumbsup:
link dont work...google the web address, that works, checked it
rooster51 is offline
post #3 of 14 Old 05-16-2009, 03:49 PM
subliminal
1997 XJ Cherokee
Fail
Theres no diagram for him on that link
1997 Jeep Cherokee 4.0 Automatic NP231
subliminal is offline
post #4 of 14 Old 05-16-2009, 03:50 PM
subliminal
1997 XJ Cherokee
Here ya go
http://autorepair.about.com/library/...bl202a-lib.htm
post #5 of 14 Old 05-16-2009, 05:10 PM
bcollier1823
Just for future reference, the firing order is always going to be on the intake manifold. Occasionally the distributor cap will also label which point is for the #1 cylinder.
Billy Collier
bcollier1823 is offline
post #6 of 14 Old 05-16-2009, 05:21 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
dist cap has an arrow pointing to 1, it's the one in the front left(i think), beside center front terminal as you're looking at it.
firing order is on the intake manifold, cast in huge bold numbers.
ratmonkey is offline
post #7 of 14 Old 05-16-2009, 05:43 PM
rooster51
Originally Posted by subliminal View Post
what'd I do wrong?? tried helping and ended up looking like an idiot.
I think I may be low on link fluid
post #8 of 14 Old 05-17-2009, 05:23 PM Thread Starter
ECMUDSLINGER
thanks, and yeah they usually do have them ontop the intake but this one is missing it? idk why....i cant even see my distributor cap its tucked in so tight between the firewall and motor. and i got a new one so i could change it but no luck i cant get to it, i could only change the wires....bummer
post #9 of 14 Old 05-17-2009, 05:32 PM
elmer_fud
it can be changed you just have to figure out where you can get the cap out?
did you get the spark plugs connected right?
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #10 of 14 Old 05-22-2009, 01:42 PM Thread Starter
ECMUDSLINGER
yeah spark plugs went in fine a little tight putting the wires on the cap tho..tried again today to get the cap off and no luck i cant even see the two screws to get it off...
post #11 of 14 Old 05-22-2009, 02:21 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Easy to remember on the V8
from front of motor
driver is odd 1,3,5,7
passenger is even 2,4,6,8
HighLonesome is offline
post #12 of 14 Old 05-22-2009, 04:10 PM
elmer_fud
I think I figured out what size wrench to used based on the size of the bolts on the new cap then sort of looked at where the bolts would be and removed them blindly. The tricky part for me was getting the cap out from the firewall. I had to push some wires up and twist it just right.
Brian
post #13 of 14 Old 05-22-2009, 04:59 PM Thread Starter
ECMUDSLINGER
ima try again tomorrow and hopefully have some luck....thanks for the tips....ECM
post #14 of 14 Old 05-25-2009, 03:17 PM Thread Starter
ECMUDSLINGER
just got it done...well getting the caps loose its been a paint in my *** the last hour trying to get it free.....
Need Help Asap drob951 ZJ Grand Cherokee Forum 5 08-14-2009 02:11 AM
Need Help Asap!!!! sparelink ZJ Grand Cherokee Forum 8 01-10-2009 07:23 PM
Need Help Asap Please J33Pyj ZJ Grand Cherokee Forum 4 05-19-2008 05:15 PM
BB...need help asap. nashmd454 ZJ Grand Cherokee Forum 16 05-01-2005 10:40 PM
Need Help ASAP helpmeplz101 ZJ Grand Cherokee Forum 4 04-11-2005 01:02 AM
