help please! - JeepForum.com
post #1 of 4 Old 05-30-2003, 05:49 PM Thread Starter
leslea
help please!
my 94 grand cherokee laredo wont start...wont crank, NOTHING. battery's fine, alarm's been reset, new coil, starter's fine, everything runs and lights up inside just no crank... HELP!
leslea is offline
post #2 of 4 Old 05-31-2003, 12:00 AM
pozner
won't crank over or won't start?
If it won't crank, how do you know the starter's good? Or do you mean the starter turns the engine over but the engine won't start?
If the starter does nothing, the neutral safety switch wire may be off the starter solenoid or broken. The shift lever may not be engaging the neutral safety switch in Park. Put it in "N" and try to start it. The starter solenoid may be bad.
If the starter turns the engine over, but doesn't start, check to see if the plugs are getting spark. Bad fuel pump relay, bad ign. switch.
Poz
pozner is offline
post #3 of 4 Old 05-31-2003, 04:56 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
To check if the neutral safety switch is engaging, turn the key to the ON position and move the gear selector through the gear range and back to neutral or park. Then, see if it will start.
Let us know.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #4 of 4 Old 05-31-2003, 08:23 AM Thread Starter
leslea
the safety neutral switch was off the solenoid, thanks poz!
leslea is offline
