Help please!!!!! - JeepForum.com
post #1 of 4 Old 04-13-2011, 03:23 PM Thread Starter
joeyknoll
Help please!!!!!
I have a 95 ZJ with a problem.
It starts up fine, idles fine for the most part,(a little rough at times but nothing bad), now when I put it in drive the engine dies. Only when put in drive though. Any thoughts???
Any help would be great!
joeyknoll is offline
post #2 of 4 Old 04-13-2011, 04:07 PM
LordHobbit
First principles:
clean the throttle body, including the IAC - search
tune up - search
check fuel pressure - search
test tps - search
test map - search
reset computer - search
Good luck
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #3 of 4 Old 04-13-2011, 05:16 PM Thread Starter
joeyknoll
Thanks a lot!
I've done everything but check the fuel pressure.
That's being done in about 10 min.
Pretty sure its the FPR, I do have 234K miles on her.
post #4 of 4 Old 04-13-2011, 06:27 PM Thread Starter
joeyknoll
Thanks a lot!
