Help Passenger Window Won't Work. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Help Passenger Window Won't Work.
Jeep Liberty Window RegulatorJeep Grand Cherokee Mirror - Side ViewSmittybilt Products at Oconee Off-Road!
Unread 04-22-2014, 03:48 PM   #1
janelle15901
Hi, my passenger window will not go up or down from either the passenger door controls or the drivers door control. There is no clicking or nothing when you press the button, and the door lock on that side still works. It just stopped working all the sudden. Its a 1998 Grand Cherokee limited. Thanks in advanced for any help.
janelle15901 is offline   Reply With Quote
Unread 04-22-2014, 06:16 PM   #2
coralman
coralman's Avatar
Check wires in door boot for cracking, check circuit breaker #2 after pulling it, with a ohm meter or test light to see if its closed, replace it if open. Disconnect motor from harness in door and jump 12v to it to see if it moves. Check harness plugs to PDM behind door panel to make sure they haven't come loose. PDM= passenger door module.
Move over bear.I'm tired of working on the jeep
coralman is offline   Reply With Quote
Unread 04-23-2014, 09:03 PM   #3
janelle15901
Thanks for the advice.
Unread 04-24-2014, 03:05 AM   #4
coralman
coralman's Avatar
YW. Let us know what you find.
