-   -   Help/opinions on custom long arm build!! (http://www.jeepforum.com/forum/f13/help-opinions-custom-long-arm-build-1594449/)
Mikes96zj 09-16-2013 11:44 PM
I'm mike and new to the forum so I want to be respectful to everyone's opinions and forgive me if I do or say something wrong or if I posted in the wrong area
Basically I am looking for dimensions, general knowledge or advice to assist me with the build . I've seen forums in which members were doubting the capability of the guy wanting to fabricate, that's not what i am here for. Between my knowledge as well as my fathers expertise in fabrication and our shop I know we can build this .
My shop consists of a very decent sized 5ft tall mill with digital readouts on all axis. A 4ft lathe without digital readout but I could set it up . A custom made 10x10 x,y,z plasma table. A huge supply/connection of carbon Steel stainless steel and any other metals or bushings/bearings I need . As well as the basics like mig and tig welders and a small powder coat set up.
I am wanting to build anywhere from a 4.5-6.0in long arm suspension lift with a 4 link rear end set up . Possibly a 3 link also . I can't find any info for the life of me and it would be spectacular if I could find someone who has dimensions and possibly CAD files I could pop right into my plasma cam computer
If I can't find the info on the long arm build I will also settle for a 4.5 short arm custom build .
Thanks,
Mike
PolkaPower 09-17-2013 08:29 AM
Aside from the advice you will get here, Google is a great way to find information. Type in "DIY long arms ZJ" into the search and check out the results. Also "home made long arms ZJ" is another good one.
OverlandZJ 09-17-2013 09:08 AM
Sounds like your more than capable of the fabrication, now you need to learn/figure the geometry involved. Pirate4x4 would be the place to start reading, follow Polka's advice on the search and add Pirate in search terms.
Good luck.. keep us updated.
I'm not capable of the fabrication right now so I bought Clayton's kit..
speedbucket 09-17-2013 10:41 AM
You'll need at least 5" of lift for the front three link to clear.
I can compile a list as I am wrapping up my 3link front/double triangulated rear build.
I found generic tabs cut to fit to be the best solution for link tabs
You will need to draw up some plates for stitch welding to the unibody at the link mounts
Your torch mate will come in handy more than anything.
https://fbcdn-sphotos-h-a.akamaihd.n...86840404_o.jpg
Also need to know purpose......street? Wheeler?trailer Queen?
http://mallcrawlin.com/forum/showthr...-Welding-Bible
Mikes96zj 09-18-2013 11:41 AM
Thanks for the support I've been online searching and have found a few guys modifying their existing control arms for an off road rig . I've heard of pirate4x4 so today I'm going to sit down and do a little digging on the site.
Speed bucket I am going for a daily driver still but can kick @ss on the trails. I would like to stay under 6inches of lift also. If you could, send me whatever dimensions you have and advice. It looks like your rig is coming together Nicely! I'm looking forward to getting into the fab stage of this project so I can be done with the geometry and measurements part lol
speedbucket 09-21-2013 07:10 AM
Here are my link numbers but my long arms are looooooong....
Front
https://fbcdn-sphotos-c-a.akamaihd.n...25718096_o.jpg
Rear
https://fbcdn-sphotos-e-a.akamaihd.n...05875958_o.jpg
If you use the link calculator you can open the materials tab and see your link length and whatnot.
My suspension is over kill for what I'm doing but with longer links I kept it stout. All of my links upper and lowers are 2" .250 wall Dom. Factory rubber at the axles and heims at the frame...
riot1987 09-21-2013 07:25 AM
Thats a bad *** program dude. I was thinking about making my own arms awhile back. Im glad I didnt try, there is a lot more to it then I thought.
cwick13 09-22-2013 02:51 PM
1 Attachment(s)
I built my long arms for a daily driver on over 7"of lift. I also accomidated a high pinion cad xj housing with super 30 guts. But i also built on a brand new alignment machine. And if i had access yo that gear i would have said lets gooooo... I have built 8 systems just like since after letting them drive mine... I got 12,000 miles on mick thom Atz tires and still have almost 90% life left. I have done the research and i know what works and what does for which ever direction your build would go... I have develeped and researched for yeeeeeears.. Yes most ppl do that backwards but Im stubborn.. And i love to prove ppl wrong...
The time now is 09:15 AM.
