Help no idea - JeepForum.com
post #1 of 22 Old 07-30-2011, 03:22 PM Thread Starter
marriedjeep
Help no idea
NO reverse forward in neutral i droped the pan saw small amount of copper flakes and sludge around the magnit how do i resolve this problem super cheap im broke no job and now no ride. please help any ideas as to what to do.
marriedjeep is offline
post #2 of 22 Old 07-30-2011, 04:41 PM
Falkon
Does it reverse in park? Sounds like the linkage is out of adjustment.
Falkon is offline
post #3 of 22 Old 07-30-2011, 05:00 PM
onevision
Yeah, I'd check the cable connected to your trans. If it looks okay, then disconnect it and see if you can manually set it into park. Having your trans fluid level way off can also cause that.
You say you found copper in your pan? There shouldn't be any copper parts on your trans - at least none that I can think of.
98 ZJ - custom double triangulated rear and 3-link front with 6 1/2" lift on 33"x13.5" and Teralow gearing
Wrenching pics at (slow connection) http://onevisionbeyond.com/gallery/v/jeep/
onevision is offline
post #4 of 22 Old 07-30-2011, 06:00 PM Thread Starter
marriedjeep
it looked like tiny copper flakes and sludge.It does go into park. i looked at the linkage but cant figuer out how to unhook it. I see there is a spring there but i dont see where the linkage is conected.
post #5 of 22 Old 07-30-2011, 09:59 PM
onevision
Actually the cable with the spring is the wrong one. That one just tells the transmission where the throttle position is. You want the main thick cable, although they both go to basically the same place. Either way both connectors just pop off. Pull on the very end piece (like a plastic square) directly upward. It just snaps back on. It will be hooked directly to one of two levers, which this will be the lower or bottom one.
Can't think of anything in the valve body or transmission gears that would be brass or copper, other than a couple connectors or maybe the vent tube. Lets see what works and what doesn't first, the we can figure what the metal chunks are. Check if each hear position works or not. This basically bypasses the shifter, to eliminate it as a problem.
post #6 of 22 Old 07-31-2011, 09:55 AM Thread Starter
marriedjeep
so my step dad says it sounds like the shift forks are bent or is bent how do i check that? im about to crawl under the beast now and check that linkage out i will keep u updated in 20 min or so.
post #7 of 22 Old 07-31-2011, 10:11 AM
biggoofy
If you cant get it figured out go see Tim Moye out in Lutz he is awesome!
Zack
98 Slate Grey 5.9
96 ZJ HP44 / 9" (RIP)
90 XJ on 33s (sold)
biggoofy is offline
post #8 of 22 Old 07-31-2011, 10:32 AM Thread Starter
marriedjeep
ok so i checked the linkage it seemed fine i can manually shift the gears on the tranny it seems to maybe have some play between drive and neutral. Im stumped. dont really know what im doing when it comes to the linkage or tranny. all i know is i have to get this fixed asap and super cheap like cause at the moment no jeep means no work and im expecting my first child in three weeks. im so stressed over this Thank You to all whose trying to help me on this forum.
post #9 of 22 Old 07-31-2011, 11:28 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
There are thrust washers and bushings in the trans. When they wear enough to shed flakes it is a sign of major wear on the hard parts.
no shift forks in an auto.
The fact that it still goes into park and you can start it in park means the linkage is fine and you have internal mechanical failure.
Car-part.com to find salvage yards near you with the parts.
ratmonkey is offline
post #10 of 22 Old 07-31-2011, 11:48 AM
davidcombs_03
Best of Luck!
davidcombs_03 is offline
post #11 of 22 Old 07-31-2011, 12:37 PM Thread Starter
marriedjeep
Thanks
post #12 of 22 Old 07-31-2011, 06:45 PM
onevision
So let me make sure I understand the problem. You have no reverse when using your shifter inside, but it all works fine when you manually move the lever on the trans. Is that correct?
The transmission has one thrust washer, which comes in varying thickness and is used to set the end play spacing. It's very unlikely the metal is from that. The 42/44/46 RE transmissions are all hydraulically controlled. Reverse failure is usually the result of misadjusted or damaged linkage, but can also be from your park sprag sticking, or valve body failure, or rear servo failure, or burnt front clutch.
Beware of getting parts from salvage yards for transmissions. Sure they claim it's only got xxx miles on it and it works great guaranteed. You can pick one up for around $600 and you have about a 30% chance it will work, and can take it back for a refund if it doesn't. Of course that's only after spending 8-12 hours checking it. I went through 3 before I found one that worked, and it probably only worked because I rebuilt it. Swapping a trans is no small task. Lol
post #13 of 22 Old 08-01-2011, 01:18 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
He hasn't taken the linkage off the lever yet.
Park is park
Reverse is nothing
Neutral is forward
Try starting the jeep with the lever in neutral.
post #14 of 22 Old 08-02-2011, 01:07 PM
onevision
Are you able to start it? I'm assuming yes, since neutral is drive, but do the other drive ranges (2, 1) work as they should? They only thing that will really change things so that your shifter is not what the transmission is really in, is the gearshift linkage cable. This is why I would say to check each position of the transmission by disconnecting the cable and run your Jeep in each position. This will take two people to do, as one person will need to have their foot on the brake, while the other changes to the next gear by manually moving the switch. There are like 10 possible causes covering a wide range of parts, and knowing what does and doesn't work will help eliminate like 7-8 of those
post #15 of 22 Old 08-02-2011, 02:44 PM Thread Starter
marriedjeep
IT starts fine in park and neutral. i didnt manually run the jeep cause its just me workn on it by my lonesome. i changed the filter today and put new fluid in thinkng that would help and of course it did not. The trans is A 46 RH. when i droped the pan for the most part everything looked pretty decent in side it.
Starts in park. Starts in neutral. Drive, 1 and 2 all work fine. Overdrive works when engaged. Reverse feels like park neutral moves forward. I cant push the jeep back of forward when in neutral unless i disengage the transfer case. I hope this helps define the situation a bit more.
reverse , shift linkage , tranny problem
good idea, bad idea? bustaone ZJ Grand Cherokee Forum 6 02-09-2011 12:36 AM
bad idea? sdonovan ZJ Grand Cherokee Forum 1 03-31-2010 09:33 PM
WJ 4" long arm lift with 285/75/16 32.8" good idea or bad idea? Juice_Man ZJ Grand Cherokee Forum 10 06-06-2009 03:49 PM
Good idea or bad idea?? Sure Shot ZJ Grand Cherokee Forum 8 10-30-2006 12:23 AM
Is it a bad idea? Redsand ZJ Grand Cherokee Forum 1 12-20-2005 10:55 AM
