Help, need picture or someone to tell me a color of wire on cpu - JeepForum.com
post #1 of 27 Old 09-27-2012, 12:39 AM Thread Starter
tkottikas
so long story short, had trouble with my dads zj, kept stalling. finally wiggled cpu connectors and it stalled again so i ordered a new cpu. put it in and it ran fine for a few days. then started stalling again after a week. went back to wiggling the wires and it stalled again. figured it might be a short in the connector
i opened up the connector to try and fix it but now im not sure which way to put the wires in the clip of the connector(i can rotate it 180*)
it is the very first connector closest to the engine (closest to driver side). can anyone please tell me the color of the first few wires closest to driver side (or take a picture)?
i tried to find a new connector to splice the wires as there probably is a short in there but could not find one anywhere.
the jeep is a 98 grand cherokee laredo 4.0 with select track.
any help would be very much appreciative.
tkottikas is offline
post #2 of 27 Old 09-27-2012, 06:37 AM
KoreaZJ
1994 ZJ
KoreaZJ is offline
post #3 of 27 Old 09-27-2012, 08:07 AM
JS97ZJ
You most likely didn't find anything wrong with the pins in the connectors because the problem is in the replacement PCM.
I just re soldered a PCM for a guy that had returned 4 PCMs that did the same thing. 96-98 (4.0) PCMs have a problem with the connections to boards. There not getting properly repaired and are are just getting recycled when returned for not working.You can either keep returning the PCMs until you get one that works or repair it yourself by following the instructions in the following link.
http://www.jeepforum.com/forum/f13/9...tures-1303589/
JS97ZJ is offline
post #4 of 27 Old 09-27-2012, 08:52 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Buy The Ecu From Somewhere Other Than Those Guys In Florida And You Should Be Better.
ratmonkey is offline
post #5 of 27 Old 09-27-2012, 09:13 AM
JS97ZJ
And stay away from the PCMs that come in a STANDARD brand box that says "Made in Mexico".
JS97ZJ is offline
post #6 of 27 Old 09-27-2012, 11:52 AM Thread Starter
tkottikas
hmm... well when i put the convector back in it wouldn't even start so that's why i think i bight have put it in backwards. i wont be able to look at it till i get off work. my dad bought the cpu from amazon with there life time warranty. sucks if they gave me another bad one.
if i remember all the numbers on the holes of the connector were upside down so from this diagram i should be able to figure out if i put it in right. i guess ill talk to the guys who sold it to him or try and solder it myself
post #7 of 27 Old 09-28-2012, 07:24 PM Thread Starter
tkottikas
thanks koreaZJ that diagram helped. i put the connector in the correct way but had a wire that kept coming out. trying to glue it in place so i will try it out tomorrow and hope for the best also going to find the place where it was ordered from to see if they have a good rep.
post #8 of 27 Old 10-01-2012, 02:09 PM Thread Starter
tkottikas
i think i messed something up pretty bad cause when i reconnected it the first time. it was on the wrong way. now i have it correct and the jeep wont start. it turns over just wont start. battery is good. did i short something by putting it in wrong?
any fuses or relays i should check?
post #9 of 27 Old 10-01-2012, 04:53 PM
KoreaZJ
1994 ZJ
With everything on C1 flipped 180, Pin #2 (+12v) and Pin #31 (GND) would be reversed.
Check PDC Fuse#18 (15A), this supplies +12v to Pin #2 with the key in RUN.
Also check PDC Fuse#16 and Fuse #20.
KoreaZJ is offline
post #10 of 27 Old 10-01-2012, 10:14 PM Thread Starter
tkottikas
checked all the fuses you suggested and they all look good. any one have any other ideas?
post #11 of 27 Old 10-02-2012, 10:47 AM
JS97ZJ
You might have screwed things up a bit when you reversed the wires.
Are you sure that they'er all connected correctly now?
Check that the ASD relay energizes and the fuel pump comes on when you turn the key in the run position.
You might need to measure some voltages from this point on, do you have a meter?
JS97ZJ is offline
post #12 of 27 Old 10-02-2012, 11:55 AM Thread Starter
tkottikas
yeah, i checked the diagram and they are all correct now. i do hear the fuel pump power on. i do have a meter so i can check a few things with it just not that knowledgeable on what i would need to check.
just to make sure... is the PDS inside the jeep under the passenger seat? that's where i checked the fuses mentioned in post #9.
post #13 of 27 Old 10-02-2012, 12:03 PM
JS97ZJ
The fuse box in the passenger kick panel is the Junction Box (JB). The Power Distribution Center (PDC) is just behind the battery.
Are you getting spark ? Hearing the injectors clicking. You might want to have someone help you with checking these things.
If you can get your hands on a scanner/reader it would make things a little easier. You need to find out if the PCM is operating correctly. You might have fried it.
JS97ZJ is offline
post #14 of 27 Old 10-02-2012, 12:16 PM Thread Starter
tkottikas
ok, i checked the wrong fuses then. i will check the correct PDC fuses when i get home. i have the torque app (great app btw) on my phone so i can do a scan when i get back as well.
post #15 of 27 Old 10-02-2012, 12:21 PM
JS97ZJ
JS97ZJ is offline
what color wire bdunegan ZJ Grand Cherokee Forum 6 03-03-2011 04:31 PM
HELP!!!!What color wire??????? ricerooster ZJ Grand Cherokee Forum 3 11-05-2009 05:21 PM
WJ - color of reverse wire at rear table ZJ Grand Cherokee Forum 4 02-03-2008 09:35 AM
I got new doors!! Need wire color code help!! TheDude584 ZJ Grand Cherokee Forum 5 04-23-2007 05:23 PM
Negative Ignition coil wire color.... auditaki ZJ Grand Cherokee Forum 5 11-01-2005 11:19 AM
