HELP my Jeep is dying! - JeepForum.com
post #1 of 9 Old 02-12-2011, 03:04 PM Thread Starter
jeeper96
So in the past 2 weeks my Jeep's motor has been completely shutting down randomly, but always starts back up(KNOCK ON ****ING WOOD).
For instance:
I will be driving and all of a sudden the motor shuts off completely, I lose power steering and brakes but all other electrical stuff WORKS. Depending on the situation usually the motor will die and within a second or two it comes back on through the momentum of the car (I assume).
There have been 2 occasions that it died and I needed to repeatedly hit the starter for it to run but other than that she kicks back running under her own power.
My opinion: I'm thinking its something with the fuel pump or distributor, something fuel or spark related.
Any help?
jeeper96 is offline
post #2 of 9 Old 02-12-2011, 03:08 PM
ZeeJay1997
When is the last time you changed the spark plug wires?
ZeeJay1997 is offline
post #3 of 9 Old 02-12-2011, 03:12 PM Thread Starter
jeeper96
Well I just bought it about 2 months ago and they said it had a recent tune up. I'll check the plugs but I doubt they are the problem.
jeeper96 is offline
post #4 of 9 Old 02-12-2011, 03:17 PM
ZeeJay1997
There are a lot of things that can cause your problem. i assume since you didn't say so, you do not have codes stored. You can have code without check engine light.
Try retrieving with the key, on off, on off, on off, on within 10 sec and look at the odometer.
Also try wiggling the PCM plugs and tap lightly on the PCM
post #5 of 9 Old 02-12-2011, 04:34 PM
Jeepfordan
Could be the cps. I had a problem that sounds the same as yours when I first got my jeep. No real test for it that I know of without a voltmeter and I don't know what the correct readings for t would be. Guess this wasnt a ton of help, but I would look at replacing the cps for sure
1998 XJ- 4.0/AX-15/231- 3.5" RE. 4.10 gears - 4.6 build in progress.
Jeepfordan is offline
post #6 of 9 Old 02-12-2011, 05:17 PM
Myetball
Had the same issues with a bad ASD relay. Try swapping the A/C and ASD relays and see if it goes away.
Myetball is offline
post #7 of 9 Old 02-12-2011, 06:14 PM Thread Starter
jeeper96
Sorry but what is a CPS?
jeeper96 is offline
post #8 of 9 Old 02-12-2011, 06:15 PM Thread Starter
jeeper96
Is this a direct swap? No hassle or fuss?
jeeper96 is offline
post #9 of 9 Old 02-13-2011, 08:26 AM
scottfelsen
I think the cps is the crank shaft position sensor.
scottfelsen is offline
electrical issue , fuel , jeep , motor , motor problems
jeep dying MYJEEP93 ZJ Grand Cherokee Forum 1 05-14-2008 02:26 PM
jeep keeps dying textrailkiller ZJ Grand Cherokee Forum 1 10-01-2006 08:04 PM
Dying Jeep flatlanderep ZJ Grand Cherokee Forum 7 09-15-2006 07:39 PM
Jeep May Be Dying! jigawatt77 ZJ Grand Cherokee Forum 2 11-11-2005 10:11 PM
Jeep is dying...need help. nashmd454 ZJ Grand Cherokee Forum 12 04-07-2005 03:02 PM
