Help Me Put a Distributor On... - Page 2 - JeepForum.com
post #16 of 16 Old 09-24-2013, 03:50 PM Thread Starter
question4u92
Originally Posted by OverlandZJ View Post
As your coming up with compression on #1 you can just align the harmonic balancer up with the 0 on timing cover. Lets assume the timing gears were set correctly by the rebuilder.
Take a look down the dist hole with a light, verify where the slot is on oil pump drive.. you can rotate it to where you need it with a long screwdriver.
Then drop the dist in, keeping in mind that the rotor will turn as the gear seats on the camshaft. If you find the rotor pointing past 1.. turn the rotor back a tad further as you start to drop it in..you can dial it in a tooth at a time. You will have already set the timing mark to 0 before you dropped the dist in.
Thanks man! I got it all down, now all I need is a gasket...
question4u92 is offline
