Help?! Looking for a front drive shaft '94 ZJ - JeepForum.com
post #1 of 9 Old 05-19-2013, 08:17 PM Thread Starter
bwatson
1994 ZJ
i have a 94 ZJ but have been driving with no front drive shaft. today i almost got stuck (for the second time) not having 4WD, so now i am looking for a front drive shaft. i have the weird setup that has 4Lo, 4part-time, and 4full-time. my mom's boyfriend says the drive shaft i need is the 241 but i can't seem to find that in town OR online. all i see online is 231 and 242. is he mistaken or is it just that hard to find?
(dumb question but i'm what you might call "mechanically retarded")
bwatson is offline
post #2 of 9 Old 05-19-2013, 09:34 PM
AnotherRedZj
242 is the t-case (gusts what you have) not the drive shaft. Look at the Zj section of the forum, you'll get plenty of help there.
Best bet is a jy unless you wanna come off some big cash for an upgrade like I did.
AnotherRedZj is offline
post #3 of 9 Old 05-21-2013, 09:29 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Moved to ZJ Forum and changed thread title.
Wheelin98TJ is offline
post #4 of 9 Old 05-22-2013, 03:53 AM
shaban
Looks like you need a front driveshaft from a ZJ with a 242 tcase. Ebay is the way to go, in my opinion, unless you've got good wreckers nearby that happen to have a ZJ with a 242 case or 249 with old-style driveshaft (they switched to CV joints for 249 around 96 or so)
Bought one for meself for $50 delivered (I was swapping a 249 tcase to 242 due to a dead viscous coupling)
shaban is offline
post #5 of 9 Old 05-22-2013, 02:17 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
you're looking for a drive shaft from a 93.5-95 grand cherokee with the 6cyl and automatic transmission. all three t-case options have the same length of drive shaft.
and for future reference, (don't rely on mom's boyfriend or you'll start breaking things) your case is pretty normal in jeep suv's. 2hi is obvious, it's rear wheel drive only. 2PART TIME is for use PART OF THE TIME, only in mud, loose dirt, and deep snow/ice. 4FULL TIME can be used at any time in any conditions, but you need a front drive shaft or you won't be going anywhere in that mode. 4LO is the same as 4PART TIME only with a 2.72:1 gear ratio reduction. for low speed or high torque situations offroad.
ratmonkey is offline
post #6 of 9 Old 05-26-2013, 12:58 PM Thread Starter
bwatson
1994 ZJ
thanks everyone! got the info i need and hopefully getting the part ordered today. jeepforum rocks
bwatson is offline
post #7 of 9 Old 05-26-2013, 03:55 PM
holdon
I just bought a remanufactured front drive shaft for my ZJ w/242 case. Less than 200 out the door at O`Reilly auto parts.
holdon is offline
post #8 of 9 Old 06-17-2013, 08:24 AM
Ryancj7
I have one
Ryancj7 is offline
post #9 of 9 Old 06-18-2013, 09:29 AM Thread Starter
bwatson
1994 ZJ
I got mine for $214 at Napa. Just bought a 4" lift and a steering stabilizer. Waiting on rims and tires
bwatson is offline
driveline , idiot , problem , zj
