HELP.lifting question - JeepForum.com
post #1 of 10 Old 01-25-2013, 11:20 PM Thread Starter
SpecialD
Hey guys I just got a 93 zj v6 .auto . And want to lift it for either 33s or 35s. Jeep is gonna be trailered to the trail. Just want to make it thru the trail with out issues. But not gonna be gettin crazy and crawling just want to have fun. So what is the cheapest way to lift it. Thanks
SpecialD is offline
post #2 of 10 Old 01-25-2013, 11:27 PM
ZeeJay1997
Is the CHECK ENGINE light on?
ZJ doesnt have a V-6, unless someone got really creative...
ZeeJay1997 is offline
post #3 of 10 Old 01-25-2013, 11:38 PM Thread Starter
SpecialD
I6 everyone knows what I mean .
SpecialD is offline
post #4 of 10 Old 01-25-2013, 11:41 PM
kg6mov
Hears the voices
kg6mov's Avatar
Welcome to the forum, mind the smartasses. Yes the 4.0 is an Inline 6 not a V6.
33's need about 3.5 or 4 inches of lift depending on trimming and flex. 35's are going to need 5.5 inches of lift, and pretty soon you'll want to go to 7.
33's you can run on short arms (adjustables), for 35's you really want to go to long arms unless you're Hunter, in which case you can do whatever you want.
Either way you probably want to get rid of the d35 in the back. Definitely for 35's arguable for 33's. A d44a from a jy V8 zj (post 96) will do fine for either.
Long arms get expensive fast, but if you're gonna do it you may as well do it right the first time.
kg6mov is offline
post #5 of 10 Old 01-25-2013, 11:44 PM Thread Starter
SpecialD
Thanks a lot .very usefull information. Thanks for the help
SpecialD is offline
post #6 of 10 Old 01-25-2013, 11:45 PM
PolkaPower
Cut the fenders up and go 4.5 and 35's. Put some belly armor on it and lock an 8.8 rear.
PolkaPower is online now
post #7 of 10 Old 01-25-2013, 11:52 PM
ZeeJay1997
I resemble that remark! i resigned to the fact that I'm an ******* years ago.
post #8 of 10 Old 01-28-2013, 12:16 PM
gabrod72
Just FYI 33"s and up are when you start getting serious IMHO. If you're looking to wheel on the cheap and trialing only, then just get 3.5"~4" springs, shocks and front/rear adjustable trackbars; remove front and rear anti roll bars to get more flex. I ran the crap out of my 4.0 on a teraflex 3.5" with 32" BFG MTs. Lock whatever axle you have until it blows up. Once you hit ~4.5" or so you'll probably need to start upgrading to adjustable control arms and that gets very pricey. You may also be able to trim and fit 33"s with this type of setup (on stock control arms to keep it cheap.)
_______________________________________________
WARNING: Lo barato sale caro (Cheap things often lead to more expense)
gabrod72 is offline
post #9 of 10 Old 01-28-2013, 12:53 PM
BigClay
If you want real cheap, do a front to rear swap, throw on some 33s and cut/trim/bang the fenders as needed. Now if you want reliable, then "cheap" should not be in the same sentence.
Current: 98 TJ, 33" TSLs
Past: 94 ZJ, built for the rocks
BigClay is offline
post #10 of 10 Old 01-28-2013, 01:54 PM
dnuccio
x2
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
lift advice , lift help , zj
