help.. it just died - JeepForum.com
post #1 of 20 Old 07-26-2013, 05:05 PM Thread Starter
Jameswj4
alright so driving home in the 94 5.2 4x4 zj. It started making a knocking noises like the valves or something then next thing I no it just dies.
I got it home. When I try to turn it over it turns but doesnt fire.
Any ideas what happened. Oil level hasnt changed and the block is solid
'04 WJ "Sherry" 4.0L RCX 4in lift on 265/75/16 BFG ATs DD/Trail rig- uniden 505xl 4ft firestik- custom roof Rack- custom rear and front shackle tabs-
Jameswj4 is offline
post #2 of 20 Old 07-26-2013, 09:14 PM
JS97ZJ
Listen for the fuel pump.
JS97ZJ is offline
post #3 of 20 Old 07-26-2013, 09:29 PM Thread Starter
Jameswj4
I think its more than that cuz it doesnt sound like its getting a spark
Jameswj4 is offline
post #4 of 20 Old 07-27-2013, 01:40 AM
jabba974
Check your timing...Possible that you broke a camshaft....
jabba974 is offline
post #5 of 20 Old 07-27-2013, 01:43 AM
Area11
Did you put more gas in it?
Area11 is offline
post #6 of 20 Old 07-27-2013, 07:04 AM Thread Starter
Jameswj4
Its at a half tank. It has 230k miles so I guessing something had to break inside. . So im either gonna take her all apart and see if I can fix it. Or just get a new engine
Jameswj4 is offline
post #7 of 20 Old 07-27-2013, 08:00 AM
dusterdude
Timing chain and/or gears
dusterdude is offline
post #8 of 20 Old 07-27-2013, 08:07 AM
zj97ltd
Pull a valve cover and try to turn it over. See if the rockers move. If not, x2 on timing chain. You could pull the distributor cap too and see if the rotor turns, but I think the valve cover will be much easier.
zj97ltd is offline
post #9 of 20 Old 07-27-2013, 10:01 AM Thread Starter
Jameswj4
Alright thanks. Yea im honna pull it in the garage tomorrow and start taking things apart n see. What I find
Jameswj4 is offline
post #10 of 20 Old 07-28-2013, 02:08 PM Thread Starter
Jameswj4
Alright I got the intake manifold off.. the both the crank and camshalfs rotate when I turn the pully/vibration dampener. I have a feeling its the timing chain. But um not sure so thats the next thing ill be checking.
Jameswj4 is offline
post #11 of 20 Old 07-28-2013, 09:56 PM
jabba974
Pull the valve cover and watch the rockers....if it is a broken cam, then the front half may still turn when you move the pulley...Had that happen on a dakota I used to have...
jabba974 is offline
post #12 of 20 Old 07-28-2013, 10:13 PM Thread Starter
Jameswj4
Alright ill check that
Jameswj4 is offline
post #13 of 20 Old 07-28-2013, 10:52 PM
dnuccio
if the timing chain was broke, the cam would not move when you turn the crank
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #14 of 20 Old 07-28-2013, 11:05 PM Thread Starter
Jameswj4
That's. What I thought but my dad thinks otherwise. Oh well im gonna keep looking
Jameswj4 is offline
post #15 of 20 Old 07-28-2013, 11:43 PM
dnuccio
your dad is incorrect, sorry
R.I.P. Ratmonkey
dnuccio is offline
