HELP!!!!!!!!!JeepGrad 93 - Page 2 - JeepForum.com
post #16 of 16 Old 01-26-2005, 05:17 PM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
Originally Posted by ohboy21
friend told me to knock on the starter and it worked car started right up gears must have got stuck thanks for all the feedback
If it works when you whack it, its most likely the brushes. Be sure to check the cable for corrosion when you work on it.
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
