HELP!!!!!!!!!JeepGrad 93 - JeepForum.com
post #1 of 16 Old 01-25-2005, 03:44 PM Thread Starter
ohboy21
can someone tell me or show with picks were the starter is and how to take it off????? TIA
ohboy21 is offline
post #2 of 16 Old 01-25-2005, 03:55 PM
mr_user
The starter on the 4.0L, which I will assume you have, is connected to the bellhousing of the motor on the passenger side. It is a long cylinder with a smaller cylinder on the top. If you can not find it, trace one of the red cables from the battery as that goes down to the starter. It is one of the easiest repairs on the 4.0, as their are two bolts and the power connections. One bolt on top, one on bottom, cable to ground, and positive feed cable from the battery.
Matt
Old: '96 ZJ 4.0, 32" MT/R's, 4.5" Lift, Mickey Thompsons, JKS Disco's
New: '02 WJ Limited 4.7L, Stock for now
mr_user is offline
post #3 of 16 Old 01-25-2005, 03:57 PM
a70eliminator
Starter
Sorry I can't show you any picks, But I can tell you it's down there by the flywheel. and there's a wire that goes to it too.
a70eliminator is offline
post #4 of 16 Old 01-25-2005, 04:00 PM Thread Starter
ohboy21
I appreciate the help i think i found it it kinda looks like a coke can next to the oil pan
ohboy21 is offline
post #5 of 16 Old 01-25-2005, 04:01 PM
JdawgZJ
well from what i saw the mechanic dude was playing with the starter and it was under the car somewhere
'93 Red ZJ Laredo ,
, 33" TrXus tires , V8 - 5.2L
(updated 9/05/05 lol)
Red Jeep Club member #256
JdawgZJ is offline
post #6 of 16 Old 01-25-2005, 08:36 PM
kentman
kentman's Avatar
2006 XK Commander
Are you sure that the starter requires removal? For all I know, maybe you just like pulling it on and off every so often for kicks. In this cold weather, I would suspect the battery over a starter in relation to hard starts, unless you are in Miami.
Kent
kentman is offline
post #7 of 16 Old 01-25-2005, 08:56 PM
mr_user
That was my next question, why do you need it off?
I mean i don't want to sound judgemental but what are you going to do with it when you get it off if you couldn't locate it?
Matt
mr_user is offline
post #8 of 16 Old 01-25-2005, 10:54 PM Thread Starter
ohboy21
I already checked the battery took to get tested and it was a good battery when the key is in the on postion and i try to cranck it it clicks once thats it. a buddy told me it could be the starter if the battery was fine
ohboy21 is offline
post #9 of 16 Old 01-25-2005, 11:11 PM
matt.x
matt.x's Avatar
sounds like my problem. do the lights dim?
my starter would just click, and yea, it was the starter ... its not hard to replace, but this was a few months ago before I started learning how to work on the ole Jeep (HINT: get a Haynes manual...). Its all of 3 bolts....
Matt
Red Jeep Club Member #237
matt.x is offline
post #10 of 16 Old 01-26-2005, 09:24 AM Thread Starter
ohboy21
friend told me to knock on the starter and it worked car started right up gears must have got stuck thanks for all the feedback
ohboy21 is offline
post #11 of 16 Old 01-26-2005, 09:50 AM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
It could be the starter solinoid. If it has gone bad that might explain the one click. Other possible problems include bad connection or corroded electric cable from battery, worn out starter brushes. All are pretty easy to fix or replace.
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #12 of 16 Old 01-26-2005, 10:02 AM
mr_user
Nice!
You're still going to want to change the starter though, tapping on it is good for a 150-crank bandage fix, but you're going to be running into the same problem possibly worse down the road. Get a refurbished starter from Advance Auto I've seen them going for less than 60 bucks.
mr_user is offline
post #13 of 16 Old 01-26-2005, 10:12 AM Thread Starter
ohboy21
Hey matt i have another problem near the manafold on the right side where the gas is feed to the engine there is a leak a small drip every 2 sec i dont know the name of the part is there a diagram of pic of the engine somewere so i can find out the name so i can buy the part?
ohboy21 is offline
post #14 of 16 Old 01-26-2005, 10:23 AM
mr_user
I PM'd ya,
keep us posted.
mr_user is offline
post #15 of 16 Old 01-26-2005, 02:46 PM Thread Starter
ohboy21
it was the fuel presure regulator got a new one popped it in no leak i still appreceate the help thank you very much
ohboy21 is offline
