Help: Jeep leaking - JeepForum.com
post #1 of 6 Old 06-29-2003, 06:26 PM Thread Starter
spichman510
spichman510's Avatar
Help: Jeep leaking
From the right side under the frame whenever the cars on (hi ac) something is leaking badly it left like a 10 foot stream from my car. Is this just water from the ac and the jeep running or what?
Spicher
-'98 5.9 Grand Cherokee-
spichman510 is offline
post #2 of 6 Old 06-30-2003, 12:06 AM
xXHotelCrazyXx
xXHotelCrazyXx's Avatar
Dont worry, just moisture dripping off the compressor, all vehicles do it.
1994 Grand Cherokee Ltd V8, Rustys 4.5 lift, Daystar 2" Spacers up front, Rustys Intake, Rustys Adjustable LCA's, 31x10.5 BFG MT's, AR 767's, 3" Carsound Cat, 3" Pipe, Flowmaster 50 Series, Mike Leach Headers, Clear corners, Billet grille, 5% tint, Front and rear Trailready Bumpers, Cowl hood www.cardomain.com/id/xxhotelcrazyxx
xXHotelCrazyXx is offline
post #3 of 6 Old 06-30-2003, 04:17 AM
Howler
Re: Help: Jeep leaking
That is the drain for you AC. If it's dripping that is good. When it doesn't That means your drain is clogged and you need to get it unplugged asap as water will start to leak inside the vehicle.
Howler
97ZJ 5.2L with 5" lift. 31" SuperSwampers TSL
To boldly go were no Grand has gone before.
Howler is offline
post #4 of 6 Old 06-30-2003, 10:57 AM Thread Starter
spichman510
muchos gracias, im learning.
Spicher
post #5 of 6 Old 06-30-2003, 11:03 AM
Howler
No prob. Better to learn this way then the other way. I learned the other way.. LOL
I periodically spray the rail where the AC drains just to make sure she stays clear of mud and what not. If you look on the pass. tire ther is a hole where you can see a bolt through. Thats the rail.
Howler
Howler is offline
post #6 of 6 Old 06-30-2003, 11:14 AM Thread Starter
spichman510
will do on my 95 laredo we went mudding and luckily i bet that thing is clogged but the ac dont work so too late.
Spicher
2007 Jeep Grand Transmission Leaking Loc WK Grand Cherokee & XK Commander Forum 27 12-13-2015 12:25 PM
Water leaking in Jeep Commander 06 joseace29 WK Grand Cherokee & XK Commander Forum 7 09-02-2014 01:11 PM
94 Jeep grand cherokee Leaking rain water crunkmasterflex ZJ Grand Cherokee Forum 16 01-22-2014 08:20 AM
AC Leaking inside and swamping my jeep mrsholdenfarms ZJ Grand Cherokee Forum 3 06-02-2009 02:40 PM
2000 Jeep Cherokee Laredo Leaking Coolant....HELP!!!! StrtFlsh420 ZJ Grand Cherokee Forum 6 11-18-2005 10:21 PM
