help!! I'm stuck I'm a parking lot - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > help!! I'm stuck I'm a parking lot
1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,Zone Offroad Body and Suspension Lift Kits, Brackets, Disc
Unread 04-14-2013, 01:52 PM   #1
Bigdjs123
I went into harbor freight to get a soldering iron and some other stuff. Drove here completely fine and a quarter tank of gas. I come out and start it and as I'm backong out of my spot it dies instantly. I shut the key off and started it and it just cranks. But now my fuel light is on and says I have no gas what so ever. Did someone just steal my gas? Or something else?
Bigdjs123 is offline   Reply With Quote Quick reply to this message
Unread 04-14-2013, 02:01 PM   #2
222Doc
did they? hard to say from here.
But most newer cars it is PITA to just hose out gas. If it was a early 70"s or older its EzPzy to get gas out. Could be a crank sensor went out as well.
But just for kicks get a can of fuel and see if that does it. If it don't, then the trouble shooting starts.
Best of luck.
http://www.parker4wheelers.net
www.bullhead4wheelersinc.com
222Doc is offline   Reply With Quote Quick reply to this message
Unread 04-14-2013, 02:12 PM   #3
ReconZJ
ReconZJ's Avatar
From the symptoms you described, it sounds like your fuel gauge sending unit is failing. When my '97 was only 3 months old, I had to have mine replaced under warranty while on a road trip. Just as the engine died on the highway, the fuel gauge showed 1/4 - 1/3 still left; however, the dealership found the tank was empty. Drive it for awhile but don't let it get past 1/2 tank, and it you don't experience the problem again, you'll know.
'14 WK2 Summit 3.0 CRD Deep Auburn Pearlcoat
'97 ZJ - lifted, locked & loaded
'81 280ZX - original condition, p/t DD, weekend cruiser
'72 240Z - in storage, needs everything
'02 S10 Xtreme - for sale soon
ReconZJ is online now   Reply With Quote Quick reply to this message
Unread 04-14-2013, 02:15 PM   #4
classicmetalman
Do you hear the fuel pump when you turn the key to "on" ? If not try switching the relay in the PDC under the hood with a good one. Beyond that, a can of gas or like previously said.....
Robert
93 Laredo 4.0
96 Limited 4.0
[QUOTE=murphydajeep;9487478]I say you should still hit something just to let it know you mean business, or shake a hammer at it in a menacing fashion[/QUOTE]
classicmetalman is offline   Reply With Quote Quick reply to this message
Unread 04-14-2013, 02:34 PM   #5
Bigdjs123
I do hear it and I put about 2 gallons in it and it still nothing. When I trun the key to on and the pump just keeps running.
Unread 04-14-2013, 02:42 PM   #6
Oldfrog
Disconnect the battery ground for 5 min and then retry.
Cajun Recipes and Fishing tips
On 7th PCM. Finally got a good one.
Stalling? Work through Zeejay's list
God Bless the Garland, TX Police Dept.
Oldfrog is offline   Reply With Quote Quick reply to this message
Unread 04-14-2013, 02:48 PM   #7
Bigdjs123
Trying it now
Unread 04-14-2013, 02:57 PM   #8
Bigdjs123
Tried it and still nothing. And the fuel pump still keeps running with the key on
Unread 04-14-2013, 03:10 PM   #9
Bigdjs123
With key on it also does not ready battery voltage
Unread 04-14-2013, 03:18 PM   #10
KoreaZJ
1994 ZJ
Check fuses in PDC and Junction Block.
Got fuel pressure at the rail? Got spark?
KoreaZJ is offline   Reply With Quote Quick reply to this message
Unread 04-14-2013, 03:27 PM   #11
Bigdjs123
Yeah all of those sre good and great pressure at the rail. I just tried hooking up my scan to and it won't connect and I'm getting no reading from anything the computer controls
Unread 04-14-2013, 03:29 PM   #12
Bigdjs123
And I'm also getting all idiot lights eccept check egine light when I first turn the key
Unread 04-14-2013, 03:35 PM   #13
Mickey_D
Hate to say it, but isn't the CEL the indicator of a pass of the ECU/BCM self test? So if there's no light, the ECU/BCM failed.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
Mickey_D is offline   Reply With Quote Quick reply to this message
Unread 04-14-2013, 03:37 PM   #14
sebian
I guess of all places, Harbor Freight lot is not a bad place to break down. Easier access to the tools you need to figure it out!
Definitely check out the fuses, just because they are cheap and easy to replace if needed. You can probably get the fuel pressure tester at HF for about $30, and a tool to check for spark. Hopefully you have a multi meter with you so you can check the crank position sensor. Found a diagram of how and what to check for the crank sensor.
1995 ZJ 5.2L V8 318. 230,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline   Reply With Quote Quick reply to this message
Unread 04-14-2013, 03:47 PM   #15
Bigdjs123
That's what I'm thinking. Becaise I have half a talk of gas and none on the guage, the temp is above whatever the lowest is on the guage and no reading and no reading on battery voltage.
