Help im on side of the road - JeepForum.com
post #1 of 23 Old 04-11-2013, 06:38 AM Thread Starter
islangink
*SOLVED*I was going along fine and my 98 zj just dies...I have no power to anything. It cranks fine n freely just about to start but then goes back to just turning over...any ideas
islangink is offline
post #2 of 23 Old 04-11-2013, 06:50 AM
PolkaPower
You can try unhooking the battery for a few minutes and see if that works.
PolkaPower is online now
post #3 of 23 Old 04-11-2013, 07:24 AM
svons7
are you sure its getting gas? have you tried spraying some starting fluid down the throttle body?
have you tested to see if you are getting the proper amount of spark to the plugs with a voltmeter?
those are usually 2 good places to start
1996 Grand Cherokee Laredo 4x4. Np242. 3.5 IRO Benchmark. 15x8 Crager soft 8s 4in BS. 31in Goodyear Wrangler Duratracs
svons7 is offline
post #4 of 23 Old 04-11-2013, 10:40 AM
MN59ZJ
Sounds like a fuel pump fail to me.
MN59ZJ is offline
post #5 of 23 Old 04-11-2013, 10:44 AM
drewabril
x2 on the fuel pump. Listen close, see if you can hear the fuel pump prime when you turn the key from 'off' to 'run'
edit: you say no power to anything- like no lights and no radio? might not be fuel pump.
drewabril is offline
post #6 of 23 Old 04-11-2013, 10:50 AM
PolkaPower
What the tank with a rubber mallet or something to see if it gets the pump to work again.
post #7 of 23 Old 04-11-2013, 10:51 AM
speedbucket
fuel pumps when they go can be very finicky to temperature, it was mighty warm yesterday compared to the previous here in VA.
I have an old site truck that wont start if it sits in the sun, fuel pump is my guess as well
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #8 of 23 Old 04-11-2013, 10:59 AM
DickDickle
I don't know about you guys but I don't keep my volt meter in my jeep in case I break down driving Haha but that's just me. Maybe its not getting spark if you can hear the fuel pump working maybe your crank position sensor let go, could even be a fuse under the hood, that's happened to me before
DickDickle is offline
post #9 of 23 Old 04-11-2013, 11:04 AM
rooster51
Or a crank sensor rapid death
Terry
rooster51 is offline
post #10 of 23 Old 04-11-2013, 12:02 PM
bigb229
crank sensor...same thing happened to me two months ago...drove it to get milk....pulled it home
bigb229 is offline
post #11 of 23 Old 04-11-2013, 12:49 PM Thread Starter
islangink
*solved* the ground wire came loose from the frame
post #12 of 23 Old 04-11-2013, 12:50 PM Thread Starter
islangink
Thanks for all ur help
post #13 of 23 Old 04-11-2013, 10:00 PM
JohnCrabtree
1994 ZJ
I do. I keep 4 2x4s, a come along, a toolbox with screwdrivers, brake clean, wd40, duct tape, electrical tape, socket set, wrench set, and my volt meter!
I've used most of it in the last two months while wheeling also.
JohnCrabtree is offline
post #14 of 23 Old 04-12-2013, 05:44 AM
DickDickle
I keep a tool box with basic tools 15 foot chain 4 way jack and two come come alongs and also a chock block, as for my multimeter that stays in my tool box with all my other expensive tools at work
post #15 of 23 Old 04-12-2013, 09:24 AM
speedbucket
I would have reccomended that to check but when mine did that (ground wire off) it wouldn't even crank....
