HELP I stripped a port hole on TRansmission - JeepForum.com
post #1 of 16 Old 10-17-2012, 08:47 PM Thread Starter
marriedjeep
HELP I STRIPPED A BOLT HOLE ON TRansMission
I have a 95 with the 46 rh transmission i think lol. Anyway i had a leak at the front of the tranny from the tranny line at the fitting port and was because i installed it improperly the first time and crossed some threads. Well the long and sweet is that i stripped out the port on the tranny case how can i fix this super cheap but effective. Ive called Brandon Transmission and AMACO Transmission and without even looking at it was told by both that i need a new tranny right off the rip. I guess they assume that i dont know what im doing or talking about. Anyway any ideas or has others encounterd this problem???? Thanks for reading this and taken time to respond.
marriedjeep is offline
post #2 of 16 Old 10-17-2012, 10:45 PM
mudruna
1994 ZJ
if the threads are still there but just messed up you might be able to hit it with a tap, if not you could see about a helicoil but I'm not sure if they have them for a hydraulic application like that. you could also go ultra cheap and apply some JB weld to the fitting like thread locker and then install it and never remove it.
94 ZJ Limited- 7" IRO premium, 4.56 gears on Elockers and Chromo's, 35" claws on beadlocks, Kevin's sliders
mudruna is offline
post #3 of 16 Old 10-18-2012, 05:37 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Two options, remove and disassemble for tapping it to the next size or new transmission.
Or try to get the area completely oil free and jb Weld.
ratmonkey is offline
post #4 of 16 Old 10-18-2012, 06:26 AM
DeejayZeejay
1994 ZJ
Telfon tape the threads maybe? I've done a few jb weld fixes, only lasted temporarily.... I'd try to tap and remove any metal prices that come off during the process. Make sure you hit the fitting with a thread file to.
Jeeps 4 Life!
DeejayZeejay is offline
post #5 of 16 Old 10-18-2012, 07:32 PM Thread Starter
marriedjeep
So i bought a tap and die set today im going to lower the tranny and attempt to tap it tomorow. if that dont work jb weld sounds good. Thanks i let yall know the outcome.
post #6 of 16 Old 10-18-2012, 08:29 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
it's going to be a pipe tap, standard tap and die sets do not include pipe taper taps.
post #7 of 16 Old 10-18-2012, 08:45 PM
dusterdude
Yea,eighth or quarter pipe,dont remember which
dusterdude is offline
post #8 of 16 Old 10-19-2012, 08:34 AM
PolkaPower
I think it's 1/8th. I believe that's the size of the trans temp sender that people say to screw into the port because it's a direct fit and I am pretty sure I used a 3/8 to 1/8 adapter for it when I put it in the hard line.
PolkaPower is offline
post #9 of 16 Old 10-19-2012, 01:49 PM Thread Starter
marriedjeep
OK so heres the update. I was able to tap the hole and bought a brass fitting that fit awesome no more leak from ther. found that the pan is leaking so now i have to get a new tranny seal. Also i put in some cheap type A tranny fluid and now it feels like reverse is binding or lagging... I put in revers then i push the gas engine revs but is slow to move and when it does start theres like a whineding sound. i know my tranny is to use ATF-4 so im hoping the tranny fluid is the problem. Hardly any leaking tho lol. any ideas? could the shift linkage need to be adjusted?
post #10 of 16 Old 10-19-2012, 03:05 PM
jtackerman28
Put the right damn fluid in it.
3.5 re lift, double sheer front tb, 31" wrangler duratecs
jtackerman28 is offline
post #11 of 16 Old 10-19-2012, 03:14 PM
PolkaPower
ATF-4 and you may need a new pan too depending on if the flanges are bent from the bolts being over torqued. If they are no gasket will stop it from leaking. If not then you are good.
post #12 of 16 Old 10-19-2012, 03:17 PM
Camaro16
Ditto. ATF+4 or at a pinch +3 - you really need to get the stuff out. And change the filter at the same time - you are going to stink, for days.
Camaro16 is offline
post #13 of 16 Old 10-19-2012, 03:24 PM Thread Starter
marriedjeep
LOL i already stink with the wonderful smell of jeep insides lol. As to the fluid i will get that all changed up this weekend with the filter. what would i need to flatten the pan myself if its bent at the bolt holes? And Thanks to all for helping me threw this.
post #14 of 16 Old 10-19-2012, 03:31 PM
PolkaPower
I used a 2x4 and hammer on a very flat surface. It helped but there is still a drip every now and then. Getting a new pan one day. The bolts should only be torqued to 12.5 foot pounds.
post #15 of 16 Old 10-20-2012, 05:32 PM Thread Starter
marriedjeep
ok so i flushed the tranny and put on a new filter \ and new pan seal after having it reflattened i added hi temp rtv seal just to be safe. will put atf 4 in tomorow just so seal has plenty time to cure. fingers crossed this solves the problem.
stripped bolt , tranny cooler , tranny problem , transmission
