Help with horn that doesn't work - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Help with horn that doesn't work
WIN a Rough Country Forged Track Bar - ExtremeTerrain!FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6
Unread 07-20-2012, 12:16 PM   #1
bigislandhikers
1989 XJ Cherokee
The horn on my 1997 grand cherokee doesn't work. I think it might be the switch. The area where the switch is feels like it is empty and it doesn't seem like anything is getting "pushed" when I apply pressure to the area.
Is it difficult to get into the horn switch and replace?
Thanks
BIH
bigislandhikers is offline   Reply With Quote Quick reply to this message
Unread 07-20-2012, 01:14 PM   #2
bigislandhikers
1989 XJ Cherokee
So if there are two switches it seems one of them should work. Maybe its the horn itself?
Unread 07-20-2012, 01:40 PM   #3
Hawkeye01
Jeep horns are known for failing. Check if you have voltage to the horn. Pull the wires from the horn and have someone push the horn button on the steering wheel, use a volt meter and if every thing works ok you should get voltage at the wire connection that plugs into the horn. If there's no voltage then it could be a relay or the switch.
Semper Paratus
Hawkeye01 is offline   Reply With Quote Quick reply to this message
Unread 07-20-2012, 02:30 PM   #4
bigislandhikers
1989 XJ Cherokee
The ABS light is also on. Someone at work mentioned it could be something called a clock spring. Sound like a possibility and how would I test?
Thanks again!
Unread 07-21-2012, 09:37 PM   #5
thathubcapguy
make sure the horns are plugged in!! that was my problem there was a light impact to the r/f by a P/O and it knocked the connectors off.
thathubcapguy is offline   Reply With Quote Quick reply to this message
Unread 07-21-2012, 10:49 PM   #6
Canyon411
Can you hear the horn relay clicking when you push the switch on the steering wheel. If you can, probably the horn iself is bad. If not, could be relay or steering wheel switch.
Canyon411 is offline   Reply With Quote Quick reply to this message
Unread 07-21-2012, 11:28 PM   #7
KoreaZJ
1994 ZJ
Another horn thread... HERE
KoreaZJ is offline   Reply With Quote Quick reply to this message
Unread 07-21-2012, 11:59 PM   #8
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Any updates?
Hunter
00 4.7 Laredo...KYB gas shocks, ADDCO rear sway bar and Firestone Destination tires.
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote Quick reply to this message
Unread 07-22-2012, 03:16 PM   #9
matholland
my horn recently stopped working...I do believe that it is the switch in the horn...I was thinking about going to a junkyard and finding one that the airbag has not been deployed on and pulling it and installing in mine...IDK what a clockspring is, but it was working and I have got the horn to work a few time by pressing in a certain spot really hard.
matholland is offline   Reply With Quote Quick reply to this message
Unread 07-22-2012, 05:01 PM   #10
Snap-on
first check your horns apply direct power to them and see if they honk if the do you know have a place to start
Snap-on is offline   Reply With Quote Quick reply to this message
Unread 07-22-2012, 05:43 PM   #11
matholland
They do I'm almost positive that it's that switch on the horn
Unread 07-22-2012, 09:04 PM   #12
Canyon411
Thanks
BIH
Any progress? Did you check for the sound of the relay clicking or not?
Unread 07-23-2012, 10:30 AM   #13
bigislandhikers
1989 XJ Cherokee
I checked with a meter and didn't have any power going to the horns. It sometimes barely works and it blows very weakly. When it does its for only a couple times and then stops.
I will listen for a relay click tonight but I'm pretty sure there was none.
Should I feel anything pushing down when I use the horn? It feels very empty under the horn cover and nothing pushes down. Is there any way I can remove the skin off the steering wheel so I can see the horn switch?
Thanks for the help!
Unread 07-23-2012, 11:11 AM   #14
JS97ZJ
Here is the wiring dia for that part,
The power is not going to get to the horn if the relay doesn't energize. Check for power up through the columb.
JS97ZJ is offline   Reply With Quote Quick reply to this message
Unread 07-23-2012, 05:38 PM   #15
Canyon411
You could just have oxidation on the legs of the relay (in the engine compartment power dist block.) The 93-95 horn relays are under the glovebox in a much more protected environment. Pull the relay and re-seat it several times to cut a clean copper path thru the oxidation and see if they work correctly. If not and the problem still exists, I would take apart the switches at the wheel and see if the star shaped contacts have slipped out of postition or are oxidized as well.
