Help with horn that doesn't work - Page 2 - JeepForum.com
post #16 of 19 Old 07-24-2012, 07:57 AM Thread Starter
bigislandhikers
1989 XJ Cherokee
Originally Posted by Canyon411 View Post
You could just have oxidation on the legs of the relay (in the engine compartment power dist block.) The 93-95 horn relays are under the glovebox in a much more protected environment. Pull the relay and re-seat it several times to cut a clean copper path thru the oxidation and see if they work correctly. If not and the problem still exists, I would take apart the switches at the wheel and see if the star shaped contacts have slipped out of postition or are oxidized as well.
Thanks. Will give that a shot. Is there a way to remove the wheel cover without taking apart the wheel?
Thanks
BIH
bigislandhikers is offline
post #17 of 19 Old 07-24-2012, 08:26 AM
matholland
theres 3 bolts at the back of the steering wheel that once removed the whole horn/airbag assembly comes off together.
matholland is offline
post #18 of 19 Old 07-24-2012, 09:12 AM
KoreaZJ
1994 ZJ
No repair for a bad switch, need to replace the airbag trim cover.
Rather than disturbing the airbag and cover, check switch operation with an ohmmeter...
  1. First disconnect the negative battery cable, wait a few minutes for circuits to discharge
  2. Remove steering column lower shroud cover
  3. Remove the clock spring connector (white), then check the switch operation with an ohmmeter between Pins#4 and #5.
KoreaZJ is offline
post #19 of 19 Old 06-09-2013, 05:40 PM
AllenTC2
Hey guys, sorry to necropost, but this thread had something in it that may apply to me. Now I'm not a mechanic or electrically saavy, so bear with me....
The diagram on the first page shows the horn switch being in a dotted-line box called the "vehicle speed controller". Does that also have to do with the cruise control? Both my horn AND cruise control do not work, and it occurred to me that it could be something in the wiring.
Thanks for any tips you can give me!
AllenTC2 is offline
Horn doesn't work when pressing steering wheel; horn does chirp when arming/panic cmassey_2006 WK Grand Cherokee & XK Commander Forum 8 01-06-2013 10:27 PM
Keyless Entry - Panic doesn't work or horn chirp kabrewski ZJ Grand Cherokee Forum 0 03-30-2010 06:51 PM
WK 05 GC Fan doesn't work. keiobrie WK Grand Cherokee & XK Commander Forum 1 07-09-2009 12:17 AM
Key Fob Doesn't Work. Help!?! Tamella2 ZJ Grand Cherokee Forum 3 04-06-2006 09:48 PM
A/C fan doesn't work. lizardking ZJ Grand Cherokee Forum 3 08-09-2005 09:36 PM
