Help, hard to start my Grand Cherokee - JeepForum.com
post #1 of 10 Old 02-25-2006, 11:11 AM Thread Starter
bruceyg
It just keep turning over and takes long time to start, I changed fuel filter, seems doesn't help. I added fuel injector cleaner and COLD Start gas treatment, works, and easier to start my jeep. But when I stop using it the problem comes back. What am I gonna do? I don't wanna use fuel injector cleaner once a tank. Any idea?
bruceyg is offline
post #2 of 10 Old 02-25-2006, 01:37 PM
Wiley
Wiley's Avatar
I'd have the battery tested, there may be a bad cell. Take it to Autozone or some parts store, they'll test it for you for free. Also, test to make sure your'e getting enough fuel and spark. Good luck.
Justin
1993 ZJ Laredo
5.2 V8 4" lift 31s JKS f & r track bars JKS discos Cragar Soft 8s DT 3000s OME Stabilizer
K&N drop-in Dynomax Exhaust Hella 500s Westin Safari Bar KOR Radiator Support
Dark Rosewood Jeep Club Member #5
Wiley is offline
post #3 of 10 Old 02-25-2006, 11:19 PM Thread Starter
bruceyg
I changed a new battery acouple of weeks ago. I don't think it's the problem of ignition system, probabaly it's fuel system or IAC, when I used fuel injector cleaner and cold start treatment ,the jeep is easy to be started. it's 93 six cylinder model.
bruceyg is offline
post #4 of 10 Old 02-25-2006, 11:22 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Before you crack over the engine leave the key in the "On" position for a couple seconds and then start-er-up. If that solves it the problem is simply that your fuel pump needs to re-prime the fuel lines and is a pretty common problem with ZJ's (though you didn't way which year/engine you have (*wink wink*))...
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #5 of 10 Old 02-25-2006, 11:26 PM Thread Starter
bruceyg
Yes, you are right, it's 1993 4.0L I6 model, what do you mean re-prime the fuel? Do you mean each time I start the jeep I should turn the key to on position and wait few seconds then start it?thx
once I left the key in the "on" postion for half a minute it didn't work, sometimes if I have a good luck just got a quick start. don't know why
I changed the spark plugs, wires and distributor cap half a yr ago.
1993 ZJ I6 4.0L 148K
bruceyg is offline
post #6 of 10 Old 02-25-2006, 11:32 PM
ArloGuthroJeep
Mr. Hyde!
Re-prime as in the fuel line looses pressure and it takes the fuel pump a couple seconds to repressureize the line with fuel. Of course if leaving it in the on position for a couple seconds doesn't solve your problem it is something else most likely.
post #7 of 10 Old 02-25-2006, 11:42 PM
-Joe-
-Joe-'s Avatar
Leaving the key on wont keep the fuel lines primed as it was put. (thats the job of the check valve) You have to turn the key off then on again to have it reprime the line before starting.
The pump runs for about 1-2 seconds (closer to 1) when you first turn the key, it doesnt keep doing it when you leave the key on.
If you turn the key on, listen for the pump. Should be a faint wine coming from the rear. Turn the key off then back on and see if it starts easier. (Prime it 1-3 times and see if its easier to start)
Theres nothing there to measure the pressure and keep the pump priming with just the key on. (Unless the engine is running and then the pump is constantly is on)
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #8 of 10 Old 02-22-2015, 10:57 AM
samsonite1
Try changing your crank position sensor those cause problems with the fuel pump relay
samsonite1 is offline
post #9 of 10 Old 02-22-2015, 11:08 AM
SAR-Swimmer
I'm pretty sure he got the problem solved by now, as he's had 9 years to figure it out.
SAR-Swimmer is offline
post #10 of 10 Old 02-22-2015, 12:11 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
BURRRRRRN! I do the same darn thing!
Originally Posted by HighLonesome
coralman is offline
93 grand cherokee laredo hard to start rcelstner ZJ Grand Cherokee Forum 6 12-31-2008 05:57 PM
2002 grand cherokee hard to start lepr13665 ZJ Grand Cherokee Forum 0 10-12-2008 05:22 PM
2002 Grand Cherokee 4.7 hard start. trouser chili ZJ Grand Cherokee Forum 16 01-05-2007 07:59 PM
93 Grand Cherokee hard to start Ralphie ZJ Grand Cherokee Forum 0 11-25-2005 01:40 PM
99 Grand Cherokee-Hard to start when hot Storm1 WJ Grand Cherokee Forum 5 10-03-2002 08:22 PM
